Results 1 to 8 of 8
    dominik.m's Avatar
    Jun 2009
    POLAND
    Default VW CRAFTER DPF HELP
    HI ALL. Somebody can help with remove DPF from this Ecu?
    0281014131 074906032BB 2.5TDI EDC16CP34
    Thanks for help.
    Salute.
    marsete's Avatar
    Oct 2010
    SPAIN
    Hello friend,test and report.Regards
    dominik.m's Avatar
    Jun 2009
    POLAND
    Thanks. I think volta not work well.
    nizarben's Avatar
    Dec 2013
  5. The Following User Says Thank You to nizarben For This Useful Post:
    dominik.m (16th September, 2015)
    Jun 2012
    Do you still need dpf off made in winols (switch)???
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Only switch it not the perfect file for almost cars !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
    Jun 2012
    on vw sometimes you need to disconnect exhaust temp sensors before cat and in dpf. Switch is very good solution on vag cars....
    Riga, Latvia
    Quote Originally Posted by dominik.m View Post
    Thanks for help.
    Salute.
    Here you go, tested
  10. The Following 5 Users Say Thank You to thephenom For This Useful Post:
    capi (23rd July, 2019), dominik.m (16th September, 2015), goran81 (12th January, 2019), hbalazs (15th July, 2022), rob h (23rd March, 2018)
