Results 1 to 14 of 14
    ray-ray's Avatar
    Default Quickly Cloner & PC version Cn900
    Today I confirm that the quickly Cloner does connect to the PC version of the cn900.
    i was able to rewrite a CN2 and a CN5 (first uncheck the lock pages and write in the new number and then write button. It works like a charm. I also try to connect to the 72g box with no luck. More test in the am.
    CN5 = 72"G" or change to a CN2 = 4D60,1,2,3,67,68 next will try to change it to a 4C
    i also try to change a CN2 into a CN5 but it fail.
  2. The Following 5 Users Say Thank You to ray-ray For This Useful Post:
    Automat (16th September, 2015), HeXeN (21st September, 2015), lidons (21st September, 2015), lion0304 (16th September, 2015), stickmuon (25th January, 2016)
  3. #2
    ray-ray's Avatar
    If any new firmware was add to quickly there might be a way to add 72"G" box to the system. Who has the complete working 4D cd to run off PC. Has anyone dump the 46 box of it secret so you can also run off your PC.
  4. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    Automat (16th September, 2015), pitake (17th April, 2018)
  5. #3
    ray-ray's Avatar
    reason for post
    1.qualty of the hardware is better made then CN900. ( I have them both and have strip it down )
    2.Quickly verse ZB in reading ( quickly can read toyota "H" )
    3.quickly can write to CN,TPX,EH ZB can not write onto a CN
    4.quickly can work together with the CN900 PC version software. (eeprom by dump ready to start) also (unlocking CN2,CN5)
    5.very good price for well made hardware and battery operated. (perfect for sniffing at the car)
  6. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    HeXeN (21st September, 2015), stickmuon (12th November, 2015)
  7. #4
    Hello m8 can you post links for the buying machine + cn chips and software?
    Sent from my VOYAGER2_DG310 using Tapatalk
  8. #5
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by totalkey View Post
    Google is there for reason...
  9. #6
    lidons's Avatar
    Feb 2011
    work with TPH / TPX cloner original JMA modules?
    Carbon transponder cloning CN2-3-4 .....? or you have to be modules, Reds CN900 CN Cloner?
    excuse my English, is the best.
  10. #7
    ray-ray's Avatar
    As report here on the forum that (jma or cn900) box are the same. You can also use the 7cd disk to decode your 4D
  11. The Following User Says Thank You to ray-ray For This Useful Post:
    lidons (27th September, 2015)
  12. #8
    lidons's Avatar
    Feb 2011
    UOBD2 write a technician, he told me that with BOX-JMA TPX (4D) if you can work, but with BOX JMA-TPH (ID46) not assured.
    this means that BOX-JMA tph is not like the red box CN900?
    Quote Originally Posted by ray-ray View Post
    Ray-Ray does not understand this.
  13. #9
    7936
    Guest
    Some of the cn's have a password in them already. The 468 unit keys are 2 bucks or less in 100 but are the same as the other cn keys they have a password that keeps it to that machine. If crypto key was known could change to work as other keys (ie as jma and other cn machine keys,there all basicly the same just id is programmable). Newer asian machines might know the key and can program them. 4D battery keys can be cloned to a 4c (on tango and others) but can not be turned back into 4d do not know about chips.
    Sorry price went upto 3.70 for 46c and company is sold out of 468's (carbum)
  14. The Following User Says Thank You to 7936 For This Useful Post:
    lidons (28th September, 2015)
  15. #10
    mikajna's Avatar
    Mar 2015
    Hi Ray-ray, please I was wounder one thing, could with quickly cloner can change ID's on ID48 OEM tango copy chips, that are same chips which can change id's with CBAY and Tango, I was wounder can Quickly cloner make that to.
    Thank you in advance
  16. #11
    scotland clydebank
    i have 35 chips of 468 key pro anybody is looking for them sorry i will only send in uk bought them and unit was not in stock as they do not work with quickly the need to go pm me .
  17. #12
    Jun 2014
    CN900 Mini to be released soon.
  18. The Following User Says Thank You to dustin2014 For This Useful Post:
    Automat (25th January, 2016)
  19. #13
    Sep 2015
    Washington, DC
    I have got this cheap 46 CN900 red box with my Tango working without any problems cn900.JPG
  20. The Following 3 Users Say Thank You to Kinskeys For This Useful Post:
    godfathertre (7th March, 2016), HeXeN (18th July, 2016), ucokseparoh (26th May, 2016)
  21. #14
    ray-ray's Avatar
    Kinskeys after last update on my TCODE PRO (VAG pin read is not working)
    1. First test 2001 Jetta tryied both protocal same answer but wrong. I hook up a T300 pull the right pin.
    here is what I notice, no longer do you choose from the list of pin. Before you would get 2 pins press enter
    and 5 more would show up. It was a normal thing to choose pin 3 as it had no letters in the pin. The answer
    that my PRO was giving me was PIN number 5 which was on the list of pins via t300.
    2. Second test was on a 2004 golf diesel . Just to check my unit I use a second TCODE PRO From a friend to prove to
    him that the last upgrade had a bug. Both beta and standard had the same issue it would try to read but came back with
    a "please retry" on the menu.
    i did call it in and report it, but the person on the phone had no clue.
