thinks for tuto
and th file that produced complete.img does'it contain bomb
Hotfile.com: One click file hosting: complete.img
else i can't download the attached file infopmt.diff.zip
I am new to this forum. I have a dm500 clone that wont boot. I downloaded dream up and connected serial null cable to the box and comp. It say box is alive and speaking to us. I need help to find the right image and guidlines on how to proceed
sorry for replying to a old thread, but I want to try to make a image myself using the pre-configured environment,
so i downloaded the Vm player, but it does not regonise the file extension ?
so how would i use the pre-configured environment ?
does it only work with a certain version of the vm-player since there are more versions available for download ?
Can I connect my 500c to internet to get cable programs
i try tutorial in ubuntu 11.04 but it makes me errors ? is there any new tutorial or is still same topic (because is old)
Hello!
I'm trying to compile openpli image for DM500, but there are some errors. Could you please help?
I get sources from
i get errors:Code:svn co https://openpli.svn.sourceforge.net/svnroot/openpli openpli then cd openpli/trunk/cdk export CVS_RSH=ssh cvs -d anoncvs@cvs.tuxbox.org:/cvs/tuxbox -z3 co -P -rdreambox cd cdk ./prepare dm500 ./make dreamboximage_root
What am I doing wrong?Code:/bin/sh ./libtool --mode=compile --tag=CC powerpc-tuxbox-linux-gnu-gcc -g -O2 -DSQLITE_OS_UNIX=1 -I. -I./src -D_HAVE_SQLITE_CONFIG_H -DNDEBUG -DSQLITE_THREADSAFE=0 -DSQLITE_THREAD_OVERRIDE_LOCK=-1 -DSQLITE_OMIT_LOAD_EXTENSION=1 -c ./src/alter.c ./libtool: 1639: preserve_args+= --tag CC: not found eval: 1: base_compile+= powerpc-tuxbox-linux-gnu-gcc: not found eval: 1: base_compile+= -g: not found eval: 1: base_compile+= -O2: not found eval: 1: base_compile+= -DSQLITE_OS_UNIX=1: not found eval: 1: base_compile+= -I.: not found eval: 1: base_compile+= -I./src: not found eval: 1: base_compile+= -D_HAVE_SQLITE_CONFIG_H: not found eval: 1: base_compile+= -DNDEBUG: not found eval: 1: base_compile+= -DSQLITE_THREADSAFE=0: not found eval: 1: base_compile+= -DSQLITE_THREAD_OVERRIDE_LOCK=-1: not found eval: 1: base_compile+= -DSQLITE_OMIT_LOAD_EXTENSION=1: not found eval: 1: base_compile+= -c: not found libtool: compile: you must specify a compilation command libtool: compile: Try `libtool --help --mode=compile' for more information. make[1]: *** [alter.lo] Error 1 make[1]: Leaving directory `/home/amaru/test/openplisvn/trunk/cdk/cdk/sqlite-3.6.4' make: *** [.sqlite] Error 2
Hi, i'm trying to compile openpli for my dm500
and i saw that the file "binutils-2.15.91.0.2.tar.bz2" is not a bz2, so found it on the web and he is here if anyone need it
http://pkgs.fedoraproject.org/repo/p...91.0.2.tar.bz2
Thank you...
Hello guys,
if 5 days now that i am trying to create my own image. i have manage to build my image up to the last step which is make-flash-compress. When i try that command i get the error below:
louis3785@ubuntu:~/tuxbox-cvs/cdk$ make flash-compress
cp /home/louis3785/tuxbox-cvs/cdk/linux/arch/ppc/boot/images/zImage.treeboot /home/louis3785/tuxbox-cvs/root/cdkflash/boot/root/platform/kernel/os
mv /home/louis3785/tuxbox-cvs/root/cdkflash/boot/root/platform/kernel/bild .
/home/louis3785/tuxbox-cvs/root/cdkflash/mkcramfs-e -eb /home/louis3785/tuxbox-cvs/root/cdkflash/boot /home/louis3785/tuxbox-cvs/root/cdkflash/boot-cramfs.img
/bin/bash: /home/louis3785/tuxbox-cvs/root/cdkflash/mkcramfs-e: No such file or directory
make: *** [/home/louis3785/tuxbox-cvs/root/cdkflash/boot-cramfs.img] Error 127
i have search the internet but i didn't found anything. Please advise
Thank you in advance
louis
Put a space between mkcramfs and the -e
needs a space betwen mkcramsf and the -e like
/home/louis3785/tuxbox-cvs/root/cdkflash/mkcramfs -e -eb /home/louis3785/tuxbox-cvs/root/cdkflash/boot /home/louis3785/tuxbox-cvs/root/cdkflash/boot-cramfs.img
Why do you have -e and -eb anyway, surely -eb is enough?
HTH
Hi Gaston and thank you for your quick reply. Unfortunately i still have the same error even if i added the space as you suggested
/bin/bash: /home/louis3785/tuxbox-cvs/root/cdkflash/mkcramfs: No such file or directory
Any other suggestions??
Louis
looks like you trying to make an image using the old HEAD. that method is totaly out of date.
you need to throw away your current attempt and start again from post #116 in this thread using those instructions.
Hi Guys,
I manage ti fix my previews problem by removing the -eb but now i have another one
/home/louis3785/tuxbox-cvs/root/cdkflash/mkcramfs-e/home/louis3785/tuxbox-cvs/root/cdkflash/boot /home/louis3785/tuxbox-cvs/root/cdkflash/boot-cramfs.img
/bin/bash: /home/louis3785/tuxbox-cvs/root/cdkflash/mkcramfs-e/home/louis3785/tuxbox-cvs/root/cdkflash/boot: Not a directory
make: *** [/home/louis3785/tuxbox-cvs/root/cdkflash/boot-cramfs.img] Error 126
The very strange think is that the directory exist. Please advise
Louis
