hi all ;
plz help me ...
actually ... when i mack it my cvs and before last step
#10 Execute command: make checkout
i found this lines
find: `/home/raed/rr/root/cdkflash/root/lib/autofs/': No such file or directory
I: Using ld.so.1 as dynamic linker.
I: library reduction pass 1
713 symbols, 699 unresolved
No library provides non-weak _ZN8eZapMain8instanceE
No library provides non-weak _ZN8eZapMain16startNGrabRecordEv
No library provides non-weak _ZN8eZapMain15stopNGrabRecordEv
I: library reduction pass 2
907 symbols, 68 unresolved
I: library reduction pass 3
912 symbols, 5 unresolved
I: library reduction pass 4
cd /home/raed/rr/root/cdkflash/root/lib && ln -sf libgcc_s_nof.so.1 libgcc_s.so.1
make[1]: Leaving directory `/home/raed/rr/cdk'
raed@ubuntu:~/rr/cdk$
then i Execute command:make dreamboximage_root
and finally i got the image >>>and it was worked fine on my box
but when i want to put line for Restart Enigma and in the Execute command: rm .enigma i got error same as below
rm: cannot remove `.enigma': No such file or directory
and i get image size only 1.8 mb .....
what i do ??
please help me
and there is some things you most to know >>> i was formated me pc but before it >>> i copies the files packages from cdk/Archive in other drive .
then when i want to build new cvs image i was macked this steps ...
1 mkdir xyz
2 cd xyz
3 export CVS_RSH=ssh
4 cvs -d anoncvs@cvs.tuxbox.org:/cvs/tuxbox -z3 co -P -rdreambox .
5 cd cdk
6 chmod 755 prepare
7 i correct prepare file
8 ./prepare dmxyz
9 and in this step make checkout ...i was copies the files packages and posted to path cdk/Archive
10 make checkout
11 make dreamboximage_root
Is this maked error for compile ??
best regards
