bad solution
I have a problem with Sprinter w906 315 DPF OFF. Will anyone wants to check file you send (one is original and the other is modified DPF OFF) this modified a file DPF OFF I have used several Sprinter w906 515, now for the first time use of 315 and is a problem, then 1000 km Sprinter he began to emit smoke white smoke. By reloading software delayed the problem for some time, but the problem is not solved. Will anyone wants to check a file modified and tell me if it's OK or not.Sprinter w906 315 SW 1037505811 (DPF OFF).rarSprinter w906 315 SW 1037505811 (ORG).rar
Why bad solution?
Not fit the software?
These mate disconect temterature and presure sensor
pass pm
nikka, This sent a file which I tried immediately started well, but for a short period do not exceed 3000 RPM, then I have to start the engine again.
radelinus (3rd April, 2017)
[Quote = thephenom; 2600420] Powinno być doskonała. Odłączyć EGT i przywr?cić zawartość sadzy w DPF [/ quote]
Will this file (MB_Sprinter 315_220_CDI_1037505811_NoDPF.rar) work properly on a driver with such an ori: 1037391211.rar ?
No because its different software! dont use wrong sw on vehicles you can kill ecu or damage something!
DONT FORGET TO LEAVE THANKS + REP!!
DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
