Results 1 to 13 of 13
Thread: Renault Maxity
    dyzio's Avatar
    Jan 2014
    Racek
    Default Renault Maxity
    Hello i have problem with code key i use t300, sbb, zed full after coding it show key add or key succes coded and key wont start transponder is no locked what can be the problem i chose from menu nissan cabstar? is there any precode for this trasponder ?
    i try with meny transponder and nothing any ide?
    Jan 2011
    REUNION ISLAND
    Only remote key on cabstar / maxity
    Car won't accept transponder.
  3. The Following 2 Users Say Thank You to WISETIGER For This Useful Post:
    dyzio (17th September, 2015), p1et (22nd January, 2020)
    dyzio's Avatar
    Jan 2014
    Racek
    ohh what remote it will be?
    topclef's Avatar
    Mar 2010
    Quote Originally Posted by dyzio View Post
    the same like Nissan Micra 2 button
    if you do not have , you can use remote key for Dacia logan 2 button , but only to start , the remote not work .
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  6. The Following User Says Thank You to topclef For This Useful Post:
  7. #5
    dyzio's Avatar
    Jan 2014
    Racek
    thx i got taht remote i will check it
  8. #6
    dyzio's Avatar
    Jan 2014
    Racek
    ok all work fine remote and key thanks again dk the best
  9. The Following User Says Thank You to dyzio For This Useful Post:
    topclef (17th September, 2015)
  10. #7
    didi_du_93000's Avatar
    Dec 2009
    France Paris
    Hello,
    i have Nissan CABSTAR 2013.
    I have tested to learn key with SKP900 but SKP900 say me "WRONG PIN CODE".
    What tool can do it by OBD2. don't forget it's BCM and not NATS immo ecu.
    Regards,
  11. #8
    May 2019
    I have Renault Maxity to code .Can you give me advice ?I have true code ,xtool x100 pad 2 pro ?Do i need to program like Nissan Micra ?
  12. #9
    Dec 2016
    4 PIN code , CAN system , NAVARA same BCM
  13. #10
    May 2019
    Are you saying that if I go to a Nissan Navara and read the pin code it will add a key?Are you saying that if I go to a Nissan Navara and read the pin code it will add a key?
  14. #11
    May 2019
    Quote Originally Posted by TERMINATOR1000 View Post
  15. #12
    May 2019
  16. #13
    Dec 2016
    Quote Originally Posted by jvladaaa View Post
    yes ! all use same Type IMMO
