Results 16 to 30 of 32
  1. #16
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
  2. #17
    Aug 2015
    Indonesia
    ray-ray.. i've taken sometimes to comprehend this explanation of yours and still there are something which i miss. Hence,here i post some picts where i fail to understand how this thing works. Picts is in order as the way i understand your explanation.. Anyway ray-ray i don't have any tools yet. I view the dumps you posted online at hex-works#com (it's a work of a DK..too bad just couldn't remember that fellow' name).
    1. Flashed the original file virgin.
    How? Does it done manually (mean you do the input by your self) or some spesific tool or soft do the job (write the virgin file to the immobox hence..) generating that new virgin file? I've compared the original bin and the one that has been flashed virgin,and i notice some slightly change in the data after. The change is starting from line 000190 till the end.
    2. Register the first and the 2n master key plus the valet.
    How? does the registration of each key simply done by inserting those keys (one by one) to the ignition AFTER the flashed virgin immobox re-installed again to the car or the regstration was done by manually replacing the old key data with those 3 new keys one by one like this "flashed it virgin,replace the old 1st key data with the new one,put immobox back to the car,turn the key ON then OFF,then take immobox with the 1st key registered off of the car again then replace the old 2nd key data with the new one then re-install the immobox to the car again,turn the 2nd key ON then OFF then install it back to the car..the same process apply for the valet key. So,it needs atleast 3 times back and forth taking off and reinstalling the immobox to the car. And pin 4&13 grounded is the last thing must be done. Does it like that?
    3. What does 'married' mean?
    I notice slightly change also appears in the *married file" (married and married 2) starting from line 000190 coloumn 1,2,3 and 4. Only in married2 and married3 the data remain the sama.
    I know it's time consuming explaining this basic things and many of you infact are busy guys out there.. but i'm keen to learn and i found no where anyone who is gladly sharing their knowledge openly as ray-ray and the other DK do here. This is my first time 'dealing' with such a deep technical trick about immo after years of reading here and there.. hence i apologize for being so ignorance and would highly appreciate anyone who wish to sort out this confusion of mine.
    Thank you very much in advance.. and may this thread become useful to the other member like me who might just feel hesitant to ask.
    Best regard.
  3. #18
    ray-ray's Avatar
    If you see the Keylogic that was read off a cn900 it show you the pages of the transponder. Those pages are written into the dump and is visable. Now you have to choose if you flash virgin and register key by just inserting them in the barrel or ignition. You still would have to wait 35min. For it to marry each other immo. And Ecu ( done by jumping the obd2 4/13 together). The faster way would be to write in the Keylogic into the dump by hand and just start the car. What was learn off these is that there is ( no Keylogic in the Ecu only in the immo. Also there is no checksum that need to be figure out.
  4. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    PremierD (28th December, 2015), ucokseparoh (11th January, 2016)
  5. #19
    Aug 2015
    Indonesia
    Thanks ray-ray. I really appreciate your kindness sir.
  6. #20
    Jun 2015
    Ray Rey gm ,,, I seen you're post on adding the keys to a sequoia ... I tried the virgin dump ,,, and well first 2 times battery went dead on us ,,, and I was trying to use 4c keys finally I realized and tried the 4d keys basicslly spent the entire day there and part night no luck truck never started . I was hoping to get some help and try and understand how to add the key master key like you're post . I made a post yesterday hoping you'd see it I also put the data from the key in there I read it on my nd900
    imcan add the key but I don't want to make a mistake and be there all day again and not start the vehicle ...
    Can you please review my last post and help me thank you . I also put the bin the original bin or dump from that sequoia .
  7. #21
    ray-ray's Avatar
    Take the original dump and written in your Keylogic that you read off your cloner. Look at my Keylogic that my cn900 read then look at the dump. It's like a little puzzle all the pcs. are there just look for the pg.1 then the next and so on. If you write over the original Keylogic there is no sync need suv will just start.
  8. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    Freebsd (24th February, 2016), mojomojo (24th February, 2016)
  9. #22
    Jun 2015
    I don't know were I messed up ,,, it just like tries to start but no start shut off ... I tried to reysync .... Can I just put a verging dump and add fictitious 2nd and third key ... So that just one key the master is real and for it to start thanks well of course after the sync that is ???
  10. #23
    ray-ray's Avatar
    if you still have the orginal dump use it. Just rewrite the first key with the Keylogic off your key. No sync needed , because the Ecu handshake is in your dump. WAITE ! You did try to sync the virgin with Ecu maybe something gets changes. Best thing is to do what I said above and then sync immo. to Ecu. Once the car start can you please read the dump and post it. My though are if the sync change or does it alway stay the same. I'm going to compare dump1 to running dump. In it I should see your new Keylogic on key1 , key2&3 should stay the same. The prize will be below. Does the Ecu produce a new sync number every time you sync?
  11. #24
    Nov 2015
    I there 16 bits file format file virgin available?
  12. #25
    ray-ray's Avatar
    Why would you virginize the immo. ? Do you have time to waste? Syncing the immo. To Ecu at best it's going to take you 30min wait if you get it right the first time. Wouldn't it be better to add your key or write the key in the immo. ? But if you need a virgin
    file look in the search by the part number immo. (34010)
  13. #26
    alex_r_2001's Avatar
    New Jersey ,, USA
    Now if only someone can post a known good engine ECU dump or virgin would really help me out right now.. Im pretty sure my eeprom is corrupted on engine controller part 89611-0C560
  14. #27
    narkeleptk's Avatar
    May 2017
    USA
    Quote Originally Posted by alex_r_2001 View Post
    the ecu file is really simple. You can just do:
    Address::: 00 01 02 03 04 05
    00000000: 11 22 11 22 11 22 (or similar)
    Fill rest of buffer with 00
    then sync with immobox
  15. The Following User Says Thank You to narkeleptk For This Useful Post:
    alex_r_2001 (14th September, 2023)
  16. #28
    Sep 2023
    Sep 2023
    In my case there is no original dump I got car after someone else and the chip is empty fffffffff
    So I put virgin file
    I was thinking to add keys first on bench
    Then sync after
    But not having original I don't know if this is an option
    Can I write keys into a virgin file like that?
    Or should I add keys at the car using ignition? For virgin dump
  18. #30
    Sep 2023
    Well I've tried this car 3 different ways
    And I can get immo light turned off
    But it never syncs........
    Tried to sync it 6 times now after virgin write manual teaching keys and after virgin write with 1 key and 3 keys added to dump
    Fml
