Results 1 to 3 of 3
    waldi1979's Avatar
    Dec 2010
    Default Suzuki Vitara 1.9DDiS remove the throttle
    I have 2006 Suzuki Vitara 1.9DDiS Renault engine.
    The throttle is broken.
    I tried to ATR solution but it doesn't work (not DTC's but VTG valve is always 5%).
    ATR told me that sometimes also ERG removal helps but not in my case.
    Has anyone got tested solution?
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    the atr solution and swiftec dont work...
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
    Gdansk Poland
    Boomeer solution work 100%
