Results 1 to 11 of 11
    Jan 2009
    Default Sony surround sound connecting to Virgin
    Does anyone know how to connect a Virgin box to the Sony DAV DZ 280 Home Theatre to give surround sound? ps there is no audio optical port on system.
    Sep 2008
    is there a digital coax i think they call it like a phono connection.
    V.I.P. Member Chimaera's Avatar
    Jun 2009
    Prob with this system is the lack off audio inputs
    There's an HDMI output for passing on all-digital video (regular or upscaled) to your TV and an RGB-capable SCART output. There is, however, a DM Port connection that allows you to connect the supplied iPod/iPhone dock (or other optional adapters for MP3 players, Bluetooth devices and mobile phones) and listen to your digital music library through the system. Completing the connections are an FM antenna and colour-coded speaker terminals.
    Now whether the DM port can be adapted ive no idea but i would say its doubtfull as its prob not designed for what your after.
    unfortunatly m8 this isnt a box for adding things into
    May 2009
    typical Sony - hardly any inputs!
    Jan 2009
    Default Sony dav dz 280
    The manual shows a diagram of digital boxes connected to the tv and not the system but doesnt say whether this produces surround sound.
    Surely this must be the case otherwise why have the diagram?
    Its a Bravia TV and I was hoping that this meant that they would somehow communicate with each other automatically.
    xant14's Avatar
    Mental Mowbray
    There is no input other than the DMport. That is the only way in, if an adapter can be found. I have never heard of one.
    xant14's Avatar
    Mental Mowbray
    I have looked and looked and looked, and looked some more, a good 5 minutes I have looked, and I can't find any such adapter to coax dig, optical dig, analogue or whatever. The only adapter I can find is an ipod docking station.
    That is typical of Sony... they want kicking in their balls.. These days connectivity ought to be standardised, not new formats coming out. It's not like the DMPort is anything special, as if the only thing allowed to connect is an ipod, hence it is only good for stereo audio. Unless I am missing something.
    Looks like your home theatre system is good for playing dvd's and thats it.. oh and your stereo ipod thru 6 speakers.
    I will never buy a sony again... well, after i buy the BD350 maybe I will never buy again... well maybe..
    Default Adapter
    I got a Digital Co-Ax to Optical adaptor on E-by from
    eBay.co.uk Shop - HoundCables it might be worth contacting them.
    DK Veteran the_riddler's Avatar
    Jun 2009
    In The Workshop Or At The Pc
    Default audio=in
    Quote Originally Posted by xant14 View Post
    You should have an "audio-in" port on the front panel underneath the "function" button
    Sony all in one systems are totally useless
    I had the Dav 30 model and this had Optical input for PS3 SKY HD etc.all gooing through an Optical switching box
    The model that replaced that removed any digital audio inputs ????
    Most 5.1 all in one systems have no digital audio inputs which in this day and age is totally unacceptable.
    Basically it is just a 5.1 dvd player and thats is
    And what are they charging for it nearly?300
    The best way to go is for a5.1 amp/reciever Look for one with at least 3 HDMI Inputs that way you should avoid any lis sync issues and seperate speakers
    You could try Richer Sounds and i bet it will be cheaper than the Sony all in one
    Member ssttaagg's Avatar
    langonnet france
    i`v got a sony home theatre system, with lots of inputs. how many do you need
