Setting the file will not fix the car. Replace regulator Y75
Hello guys. I need a file for tuning MB W203 C270, I have a problem on the fuel pump. When you change the fuel pressure and drive the car above 3000 rpm then the engine switched off. Please Help. MB W203 270cdi ORG.rar
with the original file car good things, but when you load the tuning file then starts off after 3000 rpm. Here's tuning file, please check and tell me where I'm wrong.
You are wrong almost everywhere.
Don't play with the car and Titanium and without knowledge what you are doing.
Mainly... don't ask from CR pump to give more than 1400 bar. Actually, you don't need more fuel pressure to achieve more power (with those injectors, pump, etc)
Cheers!
this time your car will not stop with limp mode...but...as bobo said...do not play with this car
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
this is the result of a good tuned car
https://www.youtube.com/watch?v=iDYJ4SBxbiQ
outside forum:
macako6 (25th September, 2015)
