hi, try this one, is not my work, its a file that a get some time ago here in DK but never test
regards
Hi can any body help to mod this flash to start this car with manual gear box,please.
ecu 045906019Q
Flash 29F400.
is this possible or maybe there is some other solution.i dont have this car in my garage so its difficult for me to learn how to.
tested solution would be a grate help.
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
regards
gttuning (25th September, 2015)
Thanks will try.
Sent from my SM-G900F using Tapatalk
http://www.digital-kaos.co.uk/forums...manual-gearbox
this is my file and work
hi, by the way, what gearbox you put on car?
regards
i have the same car with same problem.When i write this dump do not work for me.After i write it do not have diag with the car and car do not start.In true with both dumps the car start for 1 sec and after stop.immo is ok.If i write again the original dump i have diag but offcourse the car do not start again.Need to do and somethink else with this dump?
