2011 CDI W221 CGW flash both and eeprom work dump need.
my abrtius original kill CGW w221. I need flash both and eeprom dump work.
regards
regards
abritus warn you to make backup about CGW flash and eprom before you start procedure. Have you done this? I'm sure abritus support will help you.
it not warning back up message.
it's in PDF manual
I dont see any info. after make read it. now need it dumps
Diesel? Petrol?
Read more carefully next time. Read eeprom, read flash of CGW.
Go to odometer calibration. Check boxes "have eeprom" and "have flash". Odometer re-calibration will take about 5-10 seconds.
GOLDEN RULE
always read and save files before doing modification mate
dave
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
Smok PSA, volvo & ford
If someone helps you DONT FORGET TO SAY THANKSits only polite....
In pdf for 221, you can read this:
and this:First of all you need to read the EEPROM and the Flash memories of the Central Gateway control unit
by using the Special Function “CGW (ZGW) Explorer). You need to store the EEPROM and Flash
dumps as files on your hard drive.
Please, note that the Abrites Commander for Mercedes will also automatically make a backup of the
EEPROM and Flash memories when it reads them. These backup files can be found in the same folder
where the software is installed (which is normally “C:\Program Files\ABRITES software for ID
XXXXXX\Mercedes”)
ATTENTION: You can speed-up the odometer correction process if you load the FLASH and
EEPROM dumps, if you have already read them with the “CGW Explorer” special function. In fact it is
recommended to always use the loaded the dumps that you have already saved.
now need manual read flash 1 and flash 2 work file. Abritus read it both and mixed file save. need it extract flashs files
yugo45 (29th September, 2015)
it have two pieces 29AL004xxxx and 95128
vanos batam (18th June, 2021)
here all dumps .
solved .
