Try this file. EGR OFF
Hi mates this is my first try with this ecu i have read it with bdm and i saw that read mic flash and eeprom.The ecu is mjd 602.a1/hw03f/2707-a140
I have problem with the egr no good operation and the car loose power.I pulled out the connector and the car is ok but i have fault lamp p0403-04.Can somebody makes egr off or dtc remove?Thanks
kospoz (30th September, 2015)
this is volta solution my friend?
Galletto v54 said checksum is not supported is there a solution?maybe someone can calculate the checksum?
these files are ok?I have read it with galletto bdm mode.A member told me that is wrong the mic bin because is 513kb and must be 483!I tried to read it with kess via can because on k line said wake up error.This is the file that i read it is enough to do egr off?
yes file is ok
FILE SERVICE
REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agricultureGenuine WinOLS user
kospoz (1st October, 2015)
write the file,i have edit your mpc file and chk are ok,dont need to be corrected
leave plug from egr connected
Mike
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
i have edit you file for size to check if chk are corrected,write the file from Mr.Dominik and leave the plug from egr connected !
Full WinOLS user
Your file Egr off.
jjrp255630 (20th March, 2017), kospoz (1st October, 2015)
