Results 1 to 8 of 8
    mariusica_boy's Avatar
    Default SOLVED - Need Help Nissan X-Trail 2.0 Dci EDC16cp33 DPF Off
    can anyone help me with DPF off on this Nissan X-Trail? I have attached the original file FULL BDM read with Galletto.
    It is a 2.0DCi. I am not looking for a ecusafe or volta file.
    Need tested solution.
    I need swiftec or winols manual solution.
    Thanks in advance.
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    incearca marius .try this pass in pm
    FILE SERVICE
    REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agriculture
    Genuine WinOLS user
  3. The Following 2 Users Say Thank You to aem For This Useful Post:
    eprst (14th December, 2015), mariusica_boy (5th October, 2015)
    Thanks. I will report.
    Thank u very much AEM.
    Your file work good.
  6. The Following 2 Users Say Thank You to mariusica_boy For This Useful Post:
    leon mag (17th January, 2016), morgano (5th October, 2015)
    Hello! I cant send private message to you mariusica_boy. Your post is full..
  8. #6
    Mar 2016
    Hi, Im doing same job soon, did you needed program injectors after writting new file?
  9. #7
    Quote Originally Posted by SvenR1 View Post
    I read full bdm and not have problem with injector code.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  10. #8
    Mar 2016
    Okey thanks, stupid question, but after changing flash data, did you wrote back only flash content or all full bdm? Also after writting do I have to unplug differential and temperature sensors or they can be left alone?
