Results 1 to 4 of 4
Hybrid View
    Default CHecking my internet connection on my FS5 box
    Hi guys
    Is there a way to check the lan connection to make sure its working ok??? My cable and homeplug are perfect running fine the free channels are all perfect the others are NOT!!!
    I tried a wireless adapter but it finds the router but times out so cant use that. Everything has been fine really upto now. The others things have all been checked if you know what i mean. No settings have changed
    Plug the lan cable into a laptop and see if it's working through the ethernet cable.
    It could be something else but we can't discuss that.
    Sent from my SM-N9005 using Tapatalk
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Suspected internet problems, 1st thing to do is switch off router, homeplugs and openbox then back on to reset network system.
    To test to see if internet is working on the openbox, try seeing if network apps work ie youpo*n or weather app works or if the xmltv epg downloads an update.
    Cheers guys....yeah the"Other" thing defo not that. Well its back this morning after leaving everything on last night as i normally switch my box off stop it getting hot over night!!
