    Jan 2013
    Default Honda FRV 2.2d 2006 dpf off
    Hi! I need dpf off. ECU Bosch 0 281 013 521 1039S19994 Honda FUB 37820-RH2-E02
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    check an report ....
    FILE SERVICE
    REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agriculture
    Genuine WinOLS user
  3. The Following User Says Thank You to aem For This Useful Post:
    HARYHARY (8th October, 2015)
    Jan 2013
    Thank you. I will be tested tomorrow and will confirm.
    VENICE
    See after writing if cruise control work fine
    Jan 2013
    The first program works. Dpf enabled but does not work cruise control. The customer does not mind. Thanks.
    aem's Avatar
    Jun 2014
    i give you 2 files.try both..........
    FILE SERVICE
    Genuine WinOLS user
