Yes no problem.
can x300m, do peugeot 208 and 508, BSI and DASH both from obd? What is procedure first do bsi and then dash, do I need to disconect dash?
rtbdiagnostic (6th March, 2019)
good day need advice 2013 Vw Polo 6r dash with red display will it work with x300m or x100pro vdo cluster could it be NEC 24c32 ?
'If I helped, please click Thanks +Reputation..!'
Today i dit vw up whit x300m 10 sec
I updated x300m.
But don't see new updates for vw Fiat Jaguar..
I only see Peugeot and Suzuki in 2019.
Anyone knows why?
I have a X300 DP PAD , currently it will not update .... for the past week , are there any issues with the servers ?
Now X100 pro have few new update but cant tick for update. Any body have same problem.
There is not issue, just you need little bit more instruction. You need every one each module choose which version you want install.
On the column from left you have....
1 which is last number update ,
then go right (or middle version) which you want install and go more to right (or last from right) currently installed.
So this middle number click there and choose last update or highest version or which you want install... then try clik on the left brand and press update.
My post helps you? Please HitButtons
