Page 191 of 232 FirstFirst ... 91141181186187188189190191192193194195196201 ... LastLast
Results 2,851 to 2,865 of 3467
  1. #2851
    Milage doctor's Avatar
    Feb 2019
    Whos complaining? Your missing the point of this forum im sure! I was looking for a solution. And keyboard warrior get a grip.
  2. #2852
    SEAT.'s Avatar
    CAPE TOWN
    Quote Originally Posted by Milage doctor View Post
    Hi Boet where u from
  3. #2853
    drpeter's Avatar
    The Netherlands
    Someone tested a evoque 2016/2017 or jaguar xe with X300M? My old x100pro does not work with these. Thanks.
  4. #2854
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    would this be UPD70F3526+93C86 version on the 2017 evoque - 2016 range rover sport with pointer same version see it is listed under coverage list
    'If I helped, please click Thanks +Reputation.. !'
  5. #2855
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by rtbdiagnostic View Post
    Yes it is the 93c86 i made it direct by tssop. But need to know if its tested, then i buy the X300M only for this car.
  6. #2856
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Quote Originally Posted by drpeter View Post
    I have tested 2016 Full LCD, it worked on X300DP, but need internet connection for adjusting...I think X300M will not work because it has no wi-fi hardware..
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  7. The Following User Says Thank You to hcip For This Useful Post:
    drpeter (20th August, 2019)
  8. #2857
    Top Poster KADE007's Avatar
    Jun 2019
    FRANCE
  9. #2858
    Feb 2017
    Baltic
    2016 continental bsi wont do by obd..
  10. The Following User Says Thank You to mikkhh For This Useful Post:
    KADE007 (20th August, 2019)
  11. #2859
    Jun 2019
    2016 Audi A3 TFSI MQB done in 2 minutes with X300M.
    Resets all trip computers/clocks etc but easy enough to set again.
  12. The Following 2 Users Say Thank You to Derryfarmer For This Useful Post:
    rtbdiagnostic (20th September, 2019), svallecilla (7th April, 2020)
  13. #2860
    Jun 2019
    FRANCE
    The thanks button does not burn, you can press it without any risk !
  14. #2861
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by DIAGAUTO 33 View Post
    Thanks for your feedback friend.
    I hesitate to buy this tool or smok ...
    Others feedback for PSA cars are welcome !
    Envoyé de mon ASUS_Z00AD en utilisant Tapatalk
    Smok is probably best tool in the market for psa
  15. The Following User Says Thank You to teerak2uk For This Useful Post:
    KADE007 (21st August, 2019)
  16. #2862
    Jun 2019
    Audi A4 2010 (Keyless) with X300m
    Removed battery from key, used key in the normal slot to start ignition (not engine) and it completed in around 25 minutes, no problems.
  17. The Following 2 Users Say Thank You to Derryfarmer For This Useful Post:
    rtbdiagnostic (22nd August, 2019), svallecilla (7th April, 2020)
  18. #2863
    Default obdstar x300 DP Plus full package
    Yesterday I did an update to my OBDSTAR X30 DP Plus. There were two stubborn makes
    kept failing update completion. As the two makes were no good use to me
    I abandoned the update. With this I found out that once update selected
    & started, it must be update completion. Otherwise the menu " Cluster Calibrate"
    would disappear from the tablet until all updates completion
    I attached a picture showing missing " Cluster Calibrate" menu(Diag Program).
  19. #2864
    Feb 2019
    common thing mate its missing until fully updated. sometimes a quick reboot solves the problem of the updates failing and then the cluster menu returns hope this helps
    Quote Originally Posted by bender View Post
  20. #2865
    frankrayk's Avatar
    Aug 2015
    42 52 41 5A 49 4C
    Can someone explain to me what is the difference between the X-100 and the X-300M? For odometer adjustment only.
    If I was useful to you, thank you by pressing the thank you button .
