levisdj (18th May, 2020), rtbdiagnostic (2nd June, 2020)
I did it via dump, did not take any chances ... thanks
brend (24th May, 2020), rtbdiagnostic (2nd June, 2020)
Hello friends, my x300m has the latest update, there are no more. FIAT V31.14
I have worked three like this.
Fiat / Freemont 2012 is chosen
Answer to: THOS
ANSWER TO: rtbdiagnostic
rtbdiagnostic (27th May, 2020)
2014 VW CC , ok. had to use passat.
DON'T JUST SAY PRESS IT.....
rtbdiagnostic (25th May, 2020)
Hello everyone!
FAIL! With X300dp Plus you cannot change KM on Fiat Palio/Strada Tablero Marelli with 95160. It only reads the Current Value.
And in the immo part, when wanting to make keys, leave the KMs at 999999 and you have to remove the board to correct it manually.
2015 Hyundai Sonata .. OK 5mins
rtbdiagnostic (4th June, 2020)
2010 Peugeout 207 odometer change (BSI) was sucsseful with X300m .
Dashboard need to reset 0km external.
Catalizator (25th June, 2020), rtbdiagnostic (12th June, 2020)
Does anyone know a way to find the real mileage on VAG cars with edc 17 after mileage on dash and dsg has been done ?
you will find old mileage in fap and egr inside ecu eeproom and tires pressure and abs it depand on the car mate
*I helped*push thanks button
x300m worlk with BSI Continental 2016
2015 Jeep Grand Cherokee, OK.
rtbdiagnostic (3rd July, 2020)
2011 grand jeep cherokee ,ok obdstar
