Page 217 of 232 FirstFirst ... 117167207212213214215216217218219220221222227 ... LastLast
Results 3,241 to 3,255 of 3467
  1. #3241
    AvechuchoAxel's Avatar
    Downey, CALIFORNIA
    You know me...i'm TERCO..... before my Jprog mysteriously disappeared from my working place it was easy..
    How you do this...OBD or just BCM?
    Sent from my SM-G965U using Tapatalk
  2. #3242
    Top Poster lexidime's Avatar
    Jun 2017
    Upstate
    No it doesn't work there's a kid running around the neighborhood with that machine doing "corrections" but if the vehicle gets corrupts he tells his customer that he'll be back he's going to get a better machine then he disappears. had 5 uhual's pull into our shop on their hands and knees. mostly - 999999/ error/ or / 475896
  3. #3243
    Jun 2016
    obdstar odomaster is now available with English, Italian, Russian, German, Spanish, Polish, Portuguese, French.
    You are required to submit your machine serial number to the dealer, and they assist change the language you need, because the default language is English.
  4. #3244
    ALEX65's Avatar
    Aug 2016
    hi guys
    i have x300m
    All cars removed from the list
    And I can not recovery
    And 555: displays unknown error
    And unfortunately obdstar support does not help
    Sent from my SM-G998B using Tapatalk
  5. #3245
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    DASHBOARD FORD RANGER 2019 MCU R7F701405 anybody had success with odomaster
    Currently listed on their website
    'If I helped, please click Thanks +Reputation.. !'
  6. #3246
    SANCHELO's Avatar
    Feb 2017
    Russia
    X300M OBD
    Jeep Cherokee from 2014 OK
  7. #3247
    Apr 2021
    Just drive it for a few miles,it will start to work
  8. #3248
    levisdj's Avatar
    EcuLand
    Quote Originally Posted by Nicolas9 View Post
    range rover sport 2013 (full lcd) - obd ok.
    (x300m)
    What did you select from the menu ? 2010- ??
  9. #3249
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Quote Originally Posted by rtbdiagnostic View Post
    One friend tried it, it can read Mileage but cannot change
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  10. The Following User Says Thank You to hcip For This Useful Post:
    rtbdiagnostic (28th April, 2021)
  11. #3250
    Oct 2019
    Tucson crdi 2019 after change km abs and two other sensor appear speedometer move up even if you are not driving
    Sent from my M2006J10C using Tapatalk
  12. #3251
    Dec 2017
    Which tool did you use to do this
  13. #3252
    hcip's Avatar
    Quote Originally Posted by ferhel19 View Post
    I have the same problem before on Fujitsu over OBDII done by OBDSTAR, Speed neddle is pointing on 10KM and not going to zero
    I fixed the problem using Iprog (original)
  14. The Following 2 Users Say Thank You to hcip For This Useful Post:
    ASCM (8th December, 2021), ferhel19 (30th April, 2021)
  15. #3253
    Oct 2019
    Quote Originally Posted by hcip View Post
    OBDSTAR odomaster po Maam what cars in Fujitsu na encuounter yung ganitong problema
  16. #3254
    hcip's Avatar
    Kia Picanto = Speed pointer stays on 10KM
    Hyundai Sta Fe = Tachometer not moving and Trip odometer not displaying, some Ligths was ON, ABS Check engine etc
  17. The Following 2 Users Say Thank You to hcip For This Useful Post:
    ferhel19 (30th April, 2021), rtbdiagnostic (14th May, 2021)
  18. #3255
    Oct 2018
    Wwwwwwwwewweweeeeeeewwwwwwwwwwwweew
    Sent from my SM-M515F using Tapatalk
