Page 218 of 241 FirstFirst ... 118168208213214215216217218219220221222223228 ... LastLast
Results 3,256 to 3,270 of 3609
  1. #3256
    Oct 2018
    Wwewww
    Quote Originally Posted by hcip View Post
    Kia Picanto = Speed pointer stays on 10KM
    Hyundai Sta Fe = Tachometer not moving and Trip odometer not displaying, some Ligths was ON, ABS Check engine etc
    Sent from my SM-M515F using Tapatalk
  2. #3257
    brend's Avatar
    Oct 2015
    Same where
    Translate to english language?...........
    Quote Originally Posted by Nitin View Post
    Wwwwwwwwewweweeeeeeewwwwwwwwwwwweew
    Wwewww
  3. #3258
    Mar 2011
    EU
    Sharan 2013 white screen 24c64,
    Smok failed
    Digi failed
    Dsp3 failed
    OBD star x300m work fine...
    Envoyé de mon LYA-L29 en utilisant Tapatalk
  4. #3259
    Oct 2019
    Anyone have successfully change Ford EcoSport 2018 RH850 ODO..??? any problem have encounter after change ODO???
    TIA
  5. #3260
    Jul 2021
    audi a7 3.0tdi 2013 obdstar (odomaster) 3 minute okay
  6. #3261
    Dec 2020
    My Iprog just read one side 4 pin, I bought another clip and it is same!!
    Have any one had this issue? and what is it solution?
  7. #3262
    frankrayk's Avatar
    Aug 2015
    42 52 41 5A 49 4C
    Quote Originally Posted by alhusinawi View Post
    Here is just for OBDSTAR...
    If I was useful to you, thank you by pressing the thank you button .
  8. The Following User Says Thank You to frankrayk For This Useful Post:
    brend (27th July, 2021)
  9. #3263
    Dec 2020
    Quote Originally Posted by frankrayk View Post
    what section is my inquiry?
  10. #3264
    Oct 2019
    Kona 2018 change mileage 100% ok .using odomaster full.
    note:
    after change mileage temp and gas gauge needle. go up you need to remove battery terminal then plug it again. then everething will be normal
  11. The Following 2 Users Say Thank You to ferhel19 For This Useful Post:
    brend (27th July, 2021), rtbdiagnostic (27th July, 2021)
  12. #3265
    brend's Avatar
    Oct 2015
    Same where
    Iprog have own forum for this.
    Quote Originally Posted by cvsjio View Post
    It is interesting of course listen about done .
    but.......
    These type dash are very capricious.
    Without backup, I would not have risked it.
  13. #3266
    Mar 2017
    canada
    sorry for my bad english whats best obdstar tool for make gm ford chrysler 2019 2020 2021 thanks
  14. #3267
    Apr 2012
    Wonderland
    can odbstar program psa dash obd?
    ProTuner since 1999
  15. #3268
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by atomiczen View Post
    barely .
    NO Selling Please !!
  16. #3269
    May 2017
    Lebanon
    guys did obdstar get an update to do renault 2014+ dashes , block synch with abs and ecu or not yet ?
    If i was helpful DONT forget the THANKS and REP button
  17. #3270
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by Moe1988 View Post
    there are lot of different renaults..
    anyway, i've tried a clio4 recently. didnt work.
