Page 228 of 241 FirstFirst ... 128178218223224225226227228229230231232233238 ... LastLast
Results 3,406 to 3,420 of 3609
  1. #3406
    Mar 2017
    canada
    2019 MITSHUBISHI OULANDER PHEV OBD2 2 MIN JOB DONE!!!!!!
  2. The Following User Says Thank You to MECANPRO0499 For This Useful Post:
    Jonesjr (10th May, 2024)
  3. #3407
    brend's Avatar
    Oct 2015
    Same where
    odomaster .
    Jaguar F-PACE (2017) , dash full led .
    ....only with online connection ......
    # Read km from dash ok
    # Write km no ! ( start write then after 5 sec stop and show no connection )...... after try , car no start enymore ,probably stuck in boot .
    Good new's.....
    Disconnect battery 1 min , ........ all ok nothing kill !
    ..........dash job done by another dump tool away ...........
    In here 93c86 .
    Good luck .
  4. The Following 3 Users Say Thank You to brend For This Useful Post:
    maybach_ (30th April, 2023), rtbdiagnostic (3rd April, 2023), sepistar (25th April, 2023)
  5. #3408
    shuvarec's Avatar
    Aug 2018
    Default OBDSTAR Mileage Correction Feedback
    Quote Originally Posted by botina View Post
    Does land rover evoque 2011-15 work with obdstar x300m?
    X300m No. odomaster yes.
    Sent from my iPad using Tapatalk
    If i help, don't forget to press thanks + rep button !!!
  6. The Following 2 Users Say Thank You to shuvarec For This Useful Post:
    brend (22nd April, 2023), rtbdiagnostic (3rd April, 2023)
  7. #3409
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by shuvarec View Post
    odomaster kills dacia duster 2021 and kills jeep wrangler 2018-
  8. The Following 7 Users Say Thank You to drpeter For This Useful Post:
    brend (3rd April, 2023), maybach_ (4th April, 2023), OdoFlasher (13th April, 2023), PremierD (12th April, 2023), rtbdiagnostic (24th April, 2023), sepistar (25th April, 2023)
  9. #3410
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Quote Originally Posted by Derryfarmer View Post
    Yes, do ABS as megane 4, it will fail but you will have the file saved to your device. then change manually and write back with megane 4.
    I tried procedure on a 2013 Clio 4 no communication check communicationetc error after attempting to read ABS with M500
    Any advice
    'If I helped, please click Thanks +Reputation.. !'
  10. #3411
    May 2015
    My Tool Room
    Perhaps you need to unplug cluster then read write abs pump then refit cluster to take on mileage from abs pump ...
    Any advice appreciated
  11. #3412
    Jun 2023
    salutations friends
    i search to to purchase tool that can read/writeeeproms from 2015 ford edge(spc+93), 2016 ford explorer(spc+24)
    this tool make claim it has this features. does this tool work to do these?
  12. #3413
    Mar 2017
    canada
    good morning !!!!have friends try 2020 hyundai kona full electric with obdstar x300
  13. #3414
    May 2015
    My Tool Room
    Quote Originally Posted by SEAT. View Post
    Yes, done my own 2015 Golf 7 R
    didi you use Obdstar X300DP Plus and NEC 35xx option instead of 2014- MQB option ?
  14. #3415
    May 2015
    My Tool Room
    2011 Volvo S60 dash program with OBDstar X300DP Plus anybody can share success .... I tried was able to read both eeprom and flash files writing mileage stays the same no change ...
  15. #3416
    May 2015
    My Tool Room
    Just tried X300DP Plus on a 2017 Hyundai i20 with D70F3421 +24c16 eeprom - was able to save the ori dump and after write showed fitst 15999999km so tried again and showed error - no luck had to remove cluster and do it by chip
    One good thing I was able to write back the ori dump I saved with X300DP plus .... must be the algo that is not good for OBDSTAR they need to have a look into this
  16. #3417
    May 2015
    My Tool Room
    Quote Originally Posted by zckariya70 View Post
    Today i try to change Hyundai I 20 Astra 2017 in Mistra option, the orginal km was 11111, my coustmer needs 2800 i tried with obdstar but it changed to 452821 its gone crazy then i tried with many km no luck at last i kept 50 km but it shows 4995 coustmer said ok.
    same happened to me had to do 24c16 chip at the back of cluster OBDSTAR sucked .....
  17. #3418
    Nov 2020
    for edge (spc5645s+93c86) it did
    explorer i didnt try but i think 2016 explorer same eeprom 93c86
  18. #3419
    Nov 2020
    kia cerato/forte 2017 done with success, use hyundai avante mb91f061bs
  19. #3420
    brend's Avatar
    Oct 2015
    Same where
    ...Odomaster ......
    Alfaromeo 159 (2008)
    Obd2 job ..............
    Read km ok
    Write can't, write llike ok but nothing change , disconnect battery no help .
    Good new's dash still ok after try .
    Job dane another tool away .
    Good luck !
  20. The Following User Says Thank You to brend For This Useful Post:
    rtbdiagnostic (21st August, 2023)
