Whos complaining? Your missing the point of this forum im sure! I was looking for a solution. And keyboard warrior get a grip.
Someone tested a evoque 2016/2017 or jaguar xe with X300M? My old x100pro does not work with these. Thanks.
would this be UPD70F3526+93C86 version on the 2017 evoque - 2016 range rover sport with pointer same version see it is listed under coverage list
'If I helped, please click Thanks +Reputation.. !'
drpeter (20th August, 2019)
2016 continental bsi wont do by obd..
KADE007 (20th August, 2019)
2016 Audi A3 TFSI MQB done in 2 minutes with X300M.
Resets all trip computers/clocks etc but easy enough to set again.
rtbdiagnostic (20th September, 2019), svallecilla (7th April, 2020)
The thanks button does not burn, you can press it without any risk !
KADE007 (21st August, 2019)
Audi A4 2010 (Keyless) with X300m
Removed battery from key, used key in the normal slot to start ignition (not engine) and it completed in around 25 minutes, no problems.
rtbdiagnostic (22nd August, 2019), svallecilla (7th April, 2020)
Yesterday I did an update to my OBDSTAR X30 DP Plus. There were two stubborn makes
kept failing update completion. As the two makes were no good use to me
I abandoned the update. With this I found out that once update selected
& started, it must be update completion. Otherwise the menu " Cluster Calibrate"
would disappear from the tablet until all updates completion
I attached a picture showing missing " Cluster Calibrate" menu(Diag Program).
Can someone explain to me what is the difference between the X-100 and the X-300M? For odometer adjustment only.
If I was useful to you, thank you by pressing the thank you button .
