Page 137 of 241 FirstFirst ... 3787127132133134135136137138139140141142147187237 ... LastLast
Results 2,041 to 2,055 of 3609
  1. #2041
    Aug 2015
    2015 Audi Q5
    X100 - not work
    300m - not work
  2. #2042
    DashProg's Avatar
    Jan 2013
    Here
    Peugeot 207 2008 BSI Valeo with 95128 read eep ok read flash ok ajust mileage ok tooks 22mns must use battery charger
    clear service history N/A
    Everything will be back in order - All my respects to DK's members.
  3. The Following 5 Users Say Thank You to DashProg For This Useful Post:
    eliaselias (30th March, 2018), Hayssam1 (4th April, 2018), lock66 (9th April, 2018), shirokov (29th March, 2018), ttzag (6th April, 2018)
  4. #2043
    shirokov's Avatar
    Sep 2009
    Cherkasy, Ukraine
    AUDI V31.61 update
    SEAT V31.61 update
    SKODA V31.61 update
    VW V31.61 update
    FORD/LINCOLN V30.47 update
    Nothing new has been added.
    Probably bug fixes and improvements.
  5. The Following 2 Users Say Thank You to shirokov For This Useful Post:
    DashProg (29th March, 2018), eliaselias (30th March, 2018)
  6. #2044
    May 2015
    Testing x300 dp full
    citroen c4 picasso 2006 no connect obd for ecu no connect bsi obd
    citroen c4 1.6 hdi 2010 no connect no read bsi obd
    citroen c5 2009 no connect bsi obd
    peugeot 308 no connect bsi obd
    peugeot 3008 no connect bsi obd
    opel vectra c 2007 no possible read pin
    Testin bsi 04ev-k05 reading outside on bench no ok no read / FVDI READ OK
    Very bad obdstart x300 dp
    paying 1000 dollars is a brick
  7. #2045
    Aug 2009
    Quote Originally Posted by DRACO21 View Post
    Do you send log file with the tool
  8. #2046
    May 2015
    Tell me how I can do it or where to get it out
    sorry for not knowing, but it is a new tool for me
  9. #2047
    Aug 2009
    Go to report center
    Did you try 30.69?
  10. #2048
    May 2015
    NO Testing V30,73 V30.72
    I have sent about 50 times during days
    nobody responds
    Has anyone tried? or does it only work badly for me? psa problem x300 dp
  11. #2049
    DashProg's Avatar
    Jan 2013
    Here
    Peugeot partner origin 2004 with BSI siemens read eep ok write eep ok mileage adjustment doesn't support
    Peugeot 207 2009 read eep ok read flash ok dosn't spport adjustment mileage write eep no wroking
  12. The Following User Says Thank You to DashProg For This Useful Post:
    shirokov (6th April, 2018)
  13. #2050
    lwood's Avatar
    Mar 2010
    city of angels
    has anyone successfully done 2015 VW Jetta?? with 100pro, or 300m
    DON'T JUST SAY PRESS IT.....
  14. #2051
    Mar 2018
    UK
    How much will cost update on X300 DP after one year?
  15. #2052
    Nov 2012
    200 usd .......
  16. The Following User Says Thank You to dorofteius For This Useful Post:
    Manta1600 (8th April, 2018)
  17. #2053
    May 2012
    & x300pro3 after on year????
  18. #2054
    dimitar's Avatar
    Quote Originally Posted by kamel2003 View Post
    Probably a waste of money anyway
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  19. The Following 4 Users Say Thank You to dimitar For This Useful Post:
    DashProg (9th April, 2018), jodge (9th April, 2018), kamel2003 (9th April, 2018), teerak2uk (9th April, 2018)
  20. #2055
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by dimitar View Post
    In the case of x100pro they are disabling options with the new ''updates'' , i tried a panamera 2009 tonight, with the old soft i never had problems with communication with the car, the latest update doesn't work anymore. Looks like OBDSTAR disable functions from x100pro to sell other tools. And they promised updates for 3 years, the last 2 years i hardly had a update. I know 3 years is too good to be true, but don't advertise with it. I don't like this company anymore. Now they even disable options. Very BAD!
  21. The Following 4 Users Say Thank You to drpeter For This Useful Post:
    DashProg (9th April, 2018), digi men (9th April, 2018), eliaselias (9th April, 2018), shirokov (9th April, 2018)
