Page 139 of 241 FirstFirst ... 3989129134135136137138139140141142143144149189239 ... LastLast
Results 2,071 to 2,085 of 3609
  1. #2071
    mecjp's Avatar
    Oct 2013
    other world
    Quote Originally Posted by Nicolas9 View Post
    is ie possible to download the old software?
    yes before load the update click right arrow beside version and you can download old version
    sharing is the key of success
  2. #2072
    hcip's Avatar
    Dec 2009
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    in X100, it can be dowload the old soft, just select on arrow in the software, but in X300DP, it is not possible, even you select the old software in onetouch update, it will display that download is finishe but when you check it the software is not installed,
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  3. The Following 2 Users Say Thank You to hcip For This Useful Post:
    DashProg (14th April, 2018), shirokov (22nd April, 2018)
  4. #2073
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    VW Amarok 24c64, screen red, by golf GTI VDO.
  5. The Following 4 Users Say Thank You to Dr. Zoidberg For This Useful Post:
    DashProg (14th April, 2018), rtbdiagnostic (1st September, 2020), shirokov (14th April, 2018), svallecilla (6th April, 2020)
  6. #2074
    Nicolas9's Avatar
    Feb 2017
    Aruba
    I was able to install 1 older (and a newer) update on my x300m.
    see here for porsche:
    i try change mileage of porsche Panamera before with 30.24, it didnt work. then i try 30.21 with my x100pro, it did work!.
    now I installed 30.23.. hope this one works also..
    And a tip: always click on 'savely remove hardware' button for usb stick. if you don't you might loose all data on sd (or better: just backup files from sd!)
  7. #2075
    Mar 2010
    UK
    When people are saying to use the old sw, how old do you mean? Or better still, which updates should we not use? I haven't updated for approx 2 months...would this class my sw as being "old version" ?
    if this post was usefull
    please press
    the thanks button
  8. #2076
    Nikola123's Avatar
    Feb 2011
    Serbia
    Skoda fabia 2014 jc nec+95320 not ok
  9. The Following User Says Thank You to Nikola123 For This Useful Post:
    DashProg (19th April, 2018)
  10. #2077
    May 2017
    Quote Originally Posted by neospeedo View Post
    2006 Chrysler 300c -> will do dash via obd but wont do SRI
    What is the SRI?
  11. #2078
    dimitar's Avatar
    Audi q7 2007 ok
    Grand cherokee 2015 ok
    Latest software version x100pro
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  12. The Following 3 Users Say Thank You to dimitar For This Useful Post:
    DashProg (23rd April, 2018), shirokov (23rd April, 2018), svallecilla (6th April, 2020)
  13. #2079
    ascrap2003's Avatar
    Sep 2016
    Texas
    What is the SRI?
    Service Reminder Most Cars Have This or other systems that hold additional info this includes but not limited to:
    Honda, Audi/VW, Benz, Chrysler, Ford etc. So hows that for all you cheap cluster repair guys $100? LMFAO I spend that much sitting down with freinds eating food, i spend more than that on a oil change! LMAO must feel fun spitting in the wind! $30K tools minimum in this bizz even then cant do all!
    Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
  14. #2080
    Feb 2017
    Baltic
    2005 T5 VW tried to change, reads ok, says it writes ok, but in dash still old km.
    tried different software versions, still no luck.
  15. #2081
    Nov 2009
    Quote Originally Posted by mikkhh View Post
    Try to reset your dash with pull off the + on the batery terminal, after make this changes.
  16. #2082
    ttzag's Avatar
    Jun 2010
    digital-kaos
    mercedes B class w245 done within 30 seconds ,
    after 5 seconds jumped to old .
    x300 pro3
    Actions speak louder than words
  17. #2083
    hcip's Avatar
    Dec 2009
    A lot of update from the site on ODO and IMMO, but I am afraid to do it, The Device may not usable?
    Any body try this latest update?
  18. #2084
    Nov 2010
    I can see updates in the update programm. My current version is listet - and the newest available version is listet. But for me the newer version is not selectable.
    If i make backup from the sd-card, and select "Format sd-card", i can only download the version i still have - not the newest one.
    Maybe my device is to old, and they dont give me further updates for free (x300M).
    Someone with the same problem?
    It will be fine, if anyone will zip the newest Versions here to download, then i can unzip them manual in the folder of my sd card...
  19. #2085
    mecjp's Avatar
    Oct 2013
    other world
    Quote Originally Posted by drkyra View Post
    contact obdstar last time that make me it, it's my update subscription that he have forgot renew and I have pay... each month it's same thing
