Page 172 of 241 FirstFirst ... 72122162167168169170171172173174175176177182222 ... LastLast
Results 2,566 to 2,580 of 3609
  1. #2566
    Aug 2015
    Quote Originally Posted by Milage doctor View Post
    Mate these models cant be done via this machine. 2013-may 2014 need a diff machine. The only machine that will do them is a smellycom or the clone the dsp3 plus
    Tried with dsp3 clone did not work
    Thos
  2. #2567
    Junior Member Joseph123's Avatar
    Nov 2017
    Holland
    Yes no problem.
  3. #2568
    May 2010
    can x300m, do peugeot 208 and 508, BSI and DASH both from obd? What is procedure first do bsi and then dash, do I need to disconect dash?
  4. #2569
    Dec 2016
    Quote Originally Posted by Thos View Post
    Thos
    are you speak about golf 7 i buy the cable becouse very people say that work....
  5. #2570
    Dec 2016
    Quote Originally Posted by SMP7 View Post
    Golf 7 2014?
    yes 02/2014
  6. The Following User Says Thank You to jacobramovich For This Useful Post:
    rtbdiagnostic (6th March, 2019)
  7. #2571
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    good day need advice 2013 Vw Polo 6r dash with red display will it work with x300m or x100pro vdo cluster could it be NEC 24c32 ?
    'If I helped, please click Thanks +Reputation.. !'
  8. #2572
    DashProg's Avatar
    Jan 2013
    Here
    Quote Originally Posted by rtbdiagnostic View Post
    good day need advice 2013 Vw Polo 6r dash with red display will it work with x300m or x100pro looks like nec 24c64
    X100 pro can do it
    Envoyé de mon SM-J400F en utilisant Tapatalk
    Everything will be back in order - All my respects to DK's members.
  9. The Following User Says Thank You to DashProg For This Useful Post:
  10. #2573
    Nov 2017
    Holland
    Today i dit vw up whit x300m 10 sec
  11. #2574
    Nicolas9's Avatar
    Feb 2017
    Aruba
    I updated x300m.
    But don't see new updates for vw Fiat Jaguar..
    I only see Peugeot and Suzuki in 2019.
    Anyone knows why?
  12. #2575
    Apr 2018
    2016 Ford Ranger - 
    Ecu negative response
    Reads original km but won’t change
    Tried current x300m software and previous one both did same thing
    Ford Ranger 2016 with SPC5645S+93C86?
  13. #2576
    j81's Avatar
    Dec 2015
    USA
    I have a X300 DP PAD , currently it will not update .... for the past week , are there any issues with the servers ?
  14. #2577
    Apr 2018
    Quote Originally Posted by jacobramovich View Post
    yes 02/2014
    X300 DP and X300 DP Plus can do
  15. #2578
    Apr 2018
    Quote Originally Posted by j81 View Post
    X300 DP PAD or X300 DP ?
  16. #2579
    Jul 2012
    In ECu
    Now X100 pro have few new update but cant tick for update. Any body have same problem.
  17. #2580
    Feb 2013
    UK Bristol
    Quote Originally Posted by ledong View Post
    There is not issue, just you need little bit more instruction. You need every one each module choose which version you want install.
    On the column from left you have....
    1 which is last number update ,
    then go right (or middle version) which you want install and go more to right (or last from right) currently installed.
    So this middle number click there and choose last update or highest version or which you want install... then try clik on the left brand and press update.
    My post helps you? Please Hit Buttons
