Have a read of the rules here mate : Forum Rules
Have a look at rule #21
Thank you...
Thank you...
EDC17CP06 is ahonda protocol
edc17C06 is BMW. and i ahve it listed in ksuite 2.08 with 4.036....
protocol 215 for OBD and 226 for tricore!
Ihlberg82 (8th October, 2015)
Mine has it...maybe bad update? or Ksuite
I paid 350Euro to have my Kess upgraded. Apparently the seller doesn?t want nothing do with you after he gets his money.
Not even an answer after sending several pm?s (Thanks a lot!!)
Maybe CP02 and C06 uses the same plugin? Could anyone be so kind and check if their kess uses P154 for C06?
It doesn't have C06 plugin but if you open the ecu after you select protocol help file window should open read it click on the coloured highlighted options blue & red on help screen they open pics of ecu boards with pinouts an direct connection pinouts
So you then choose the plugin that matches the connection you need
Ihlberg82 (14th October, 2015)
Ok Thanks! It doesn?t mention anything about C06 in the help file but it mentions "Hardware 1" and " Hardware 2"
I don?t have the ecu here with me so I can?t confirm if the C06 PCB matches any of those pictures.
