Results 1 to 9 of 9
Thread: Net id
    Sep 2010
    Default Net id
    Fitting a box at sons house he is on telewest when it comes to network scan starts off by saying already exist then starts with list when I pick one it scans but doesn't pick up all channels eg movies and sports it does pick up hd channels any help thanks
    Sep 2010
    Sorted it thanks
    Sep 2008
    thanks for not letting others know how you fixed your problem
  4. The Following User Says Thank You to cactikid For This Useful Post:
    Johnner (4th October, 2015)
    Sep 2010
    Sorry even though he only lives a mile away from me I scanned on my area which was Manchester this picked up some channels I then did his under southport and he got them all not sure if this is the correct one as all the sport channels only r really bad Glitching sorry again
  6. The Following User Says Thank You to ack1234 For This Useful Post:
    cactikid (4th October, 2015)
  7. #5
    Sep 2008
    cheers for update,if possible get correct net id off a local providers box [ things change ] to know you are selecting correct one,others are reporting glitching so it maybe not just your issue.
  8. #6
    Sep 2010
    Where do I find netid on his vir box thanks
  9. #7
    Sep 2008
    just like that.
    To find it on a Tivo box you press Home then 'Help & Settings' then 'Systems Info' then 'Diagnostics' and the top line is your net id.
    V+Box >> Press the home button on your VM remote control >>> Go to settings >>> Then technical stuff >>> Your net id is the first item on the list.
  10. #8
    Sep 2010
    Thanks for that had read up but the info I got was not for TiVo only got as far as system Info still can't understand y I get already exist for about 8 lines then it starts to find areas mine at home doesn't do this .
  11. #9
    Sep 2008
    it had stored net ids on box and 8 seems a common number,your box is missing your net id which you have to enter into box manually to scan on.
