Results 1 to 5 of 5
    Europe
    Default Peugeot partner edc17C10 DTC OFF
    Possible DTC off PEUGEOT PARTNER 1.6 HDI EDC17C10
    P1434 Multiplex additive pump . pump fault
    P1435 Multiplex additive pump CAN network fault or pump fault
    Pump and tank new and same fault ,wires too ok0281017334 KTAG MPC.rar
  2. The Following 4 Users Say Thank You to tuareg For This Useful Post:
    br.balazs (21st April, 2017), Grucha1982 (1st June, 2016), jovial (26th May, 2017), redash (9th December, 2020)
  3. #2
    Jun 2013
    EU
    Maybe need coding well them in BSI
  4. The Following User Says Thank You to morgano For This Useful Post:
  5. #3
    Europe
    Yes wright now solve problem
    To BSI coding with DIABOX without - multiplexer aditive and go to aditive ecu and select change oll complet and now ok ..
  6. The Following User Says Thank You to tuareg For This Useful Post:
  7. #4
    Jul 2011
    Hi everybody
    I've got Peugeot 308 1.6 HDI 9HP and i had same problem. After replace pump and addive tank the fault code still present.
    What I have to do was coding addive tank replace and then refill tank in engine ecu first!!! Then the same think in addive module. After that the fault code was gone. I hope I will help somebody.
    Regards.
  8. The Following User Says Thank You to Grucha1982 For This Useful Post:
  9. #5
    kinketotua's Avatar
    Apr 2016
    Europe
    if you want to try these..
    --> PARTNER_dtc_CALC_E94.rarPARTNER_dtc_CALC_E94.rar
  10. The Following User Says Thank You to kinketotua For This Useful Post:
