Results 1 to 4 of 4
    Sarkan's Avatar
    Default Golf V EDC16U34 Hot start
    The problem with the hot start, Golf 5 1.9tdi.I rewrote the part for cold starts overpart for hot start.The result is minimal.Time starts is a little shorter but still long.Please experienced tuner to look at whether it can still
    improve.
    Andrei2015's Avatar
    Oct 2015
    File look fine, you can rise a bit more if u want. In the morning starting is ok?
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
    Sarkan's Avatar
    Cold start is also a bit extended but is far shorter than the hot start
    dominik.m's Avatar
    Jun 2009
    POLAND
    When engine is hot - unplug temperature sensor and run.
    must start like cold.
