Which DTC you have now?
Are the car in limp mode, or just MIL is on.
And one more thing... what will be happened with the DPF after you make this?
Regards!
Regards!
DPF already turned off. I made a dump. Error when there is no DTC. EGR DTC shows the error sporadically but wants to solve the problem as one work.
So, which is (are) DTC number(s)?
I want to try...
Will be helpful if you give me a DPF dump.
Appendix DPF OFF. The solution from another ECU that I've made, tested and works very well.
In the afternoon I drove a car that can save the error.
Error DTC P0400 and P0409
You needed EGR off mate, DPF off make change in backpressure, all was changed and now have another error.
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
