Originally Posted by
martin035
A limitation of ABM, as there's only 9x regional ITV HD channels ie Granada, Meridian South, STV, UTV, Central west, Anglia east, London, Wales and the Generic ITV HD if your area isn't one of these ABM's scripting will tell it to swap for a nearby HD area for Tees area it will use Granada, which is no use to you, however, try this it might help;
Menu-setup-service searching-ABM then
-Delete Bouquets
-Providers and change the following;
Sky UK: Area to Tees Custom
Sky UK: FTA HD Yes
Sky UK: Swap Channels No
Green button to save and exit
- Scan
This will give you the following, all the Regional SD channels from 1 to 5 ie BBC NE&C and ITV Tynetees, all you FTA HD channels ie BBC1 HD and ITV HD will be in the FTA HD Bouquet (Channel5HD will be added soon), all other working HD channels will be in their appropriate bouquet ie sports or entertainment. ie BTsport and AMC
This is the best you can do with ABM, other options are to scan then manually edit the bouquets to move your channels to your liking via openebif interface or remote or remove ABM and try a different Plugin ie autobouquets e2
Once you're happy with your channel setup, then to set your startup channel
on the remote Fav then scroll to your startup channel then menu-set as startup service
