Page 21 of 22 FirstFirst ... 1116171819202122 LastLast
Results 301 to 315 of 324
  1. #301
    Feb 2012
    For some reason since I installed this image I cannot get film 4, more 4 and E4. Anyone else experiencing this?
  2. #302
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by MW35 View Post
    The image needs updating as its couple of months old now, once installed on your Zgemma follow the Important Notice in post 1 then rescan autoboubouquetsmaker.
  3. #303
    Mar 2016
    My clock stops working when in standby mode. It's still on the screen but does not change the time.
    As soon as I turn the box back on it moves to the right time.
    Any advice please??
  4. #304
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by Mattk1975 View Post
    Any advice please??
    You could try a software update, follow the instructions inImportant Notice in post#1 and see if that makes a difference.
  5. #305
    Mar 2016
    Can I ask where to find picon folder please do I can update..
  6. #306
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    /usr/share/enigma2/picon
  7. #307
    Feb 2013
    Grimsby
    Hi would this image work on the standard zgemma s
  8. #308
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by riley24 View Post
    Yes, but make sure to follow the important notice in post #1 to update the image once installed.
  9. #309
    Member witko's Avatar
    Jul 2008
    dublin
    were do I dl this image cant seem to find it
  10. #310
    digicon's Avatar
    Quote Originally Posted by witko View Post
    Try the first post of this thread
  11. #311
    GLOS
    Hi I had a new zgemma star 2s and I installed a new image USING THE USB METHOD. Now I want again to install another image using the same method but is not succesfull. I try factory restore but the same image comes buck, could you please help by telling me how to unistall the old image please, thanks tassos
  12. #312
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    You can't uninstall the image, you have to install a new image. What image is on the box at the moment ie openatv or openvix and what image are you try to flash on to your 2s
  13. #313
    GLOS
    Hi sorry for the delay is VIX that I put by mistake and I understand is for MaxiDigital 1000. I want to find ******** but I can,t so I would like to change the image, is any tool that can reflash as the usb method is not working any more, your help will be appreciated, thanks
  14. #314
    maca's Avatar
    Feb 2009
    liverpool
    We cant talk about it mate against the rules sorry
  15. The Following User Says Thank You to maca For This Useful Post:
    martin035 (2nd December, 2016)
  16. #315
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by tassos View Post
    Hi sorry for the delay is VIX that I put by mistake, so I would like to change the image, is any tool that can reflash as the usb method is not working any more, your help will be appreciated, thanks
    Go to this website and download an original Openatv image
    Download the zip file and on your PC, format your USB stick drive to FAT32, make a folder on the USB drive called 'imagebackups' and transfer the downloaded zip file to that folder.
    Then place the USB stick drive in your Zgemma' rear USB and switch it on
    Then on the remote;
    menu
    setup
    vix
    image manager
    blue to restore
    This will give you a default Openatv image, you can then either configure it manually or install someone backup image ie the one at post#1 of this thread
