Page 4 of 22 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 324
  1. #46
    maca's Avatar
    Feb 2009
    liverpool
    Quote Originally Posted by sheikys View Post
    thanks for the image....how do u add line ?
    5 years and you still dont know the rules..no c/s talk allowed if you forgot
  2. The Following 2 Users Say Thank You to maca For This Useful Post:
    digicon (25th November, 2015), martin035 (24th November, 2015)
  3. #47
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Updated OpenAtv5.1 Backup Image 2S & H1 26/11
    New OpenAtv5.1 Backup Image added.
    • slyk HD Skin updated to v2.0 Final
    • 'Standby' Clock Fixed
    • EMC Plugin re-install and diasbled
    As Kiddac's skin is now Finalised, this will be the final update, the only future New BackUp Images will be for software fixes to fix OTA update bugs.
  4. #48
    Feb 2012
    Can I update my ZGemma box now online through the update online in the menu of this box with this image, or will I screw all the settings up, as this seems to be a lot to update when I did a check the other day.
  5. #49
    digicon's Avatar
    You can update any image online apart from the Patched one ie: Openvix and OpenPLI
  6. The Following User Says Thank You to digicon For This Useful Post:
    martin035 (26th November, 2015)
  7. #50
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    My image is quite safe to do OTA updates, openatv is always developing via nightly updates hence the load of updates. These shouldn't affect your settings but I always advise to make your own backup once you've got your zgemma the way you want it.
  8. The Following User Says Thank You to martin035 For This Useful Post:
    digicon (28th November, 2015)
  9. #51
    Sep 2013
    Hi guys been thinking of getting a zgemma star s2 are they easy to install things any info much appreciatted cheers.
  10. #52
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by Martg View Post
    Very easy, the hard work is setting up the box, as a enigma box can be a steep learning curve. However, the backup image and instructions in post 1 has taken this hard work away.
  11. #53
    Sep 2013
    Cheers so I just download put on a flash drive boot it up hit power wait 5 mins then job done. Any chance you can tell me where i find kodi and tsmedia to install on it or can I install these on a hdd or large mem stick to use.
  12. #54
    digicon's Avatar
    You can find the Kodi addon and probably the TSmedia addon in the Plugins download section, there is enough room on the main nand flash to hold these
  13. The Following User Says Thank You to digicon For This Useful Post:
    martin035 (30th November, 2015)
  14. #55
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Basically yes, but make sure you follow the instructions to;
    1.Change you region, as ITV HD London isn't any good if you live in Scotland.
    2. Setup your USB drive for recording/epg.
    3. Setup your epg.
    As for Kodi and tsmedia to be honest there crap on a Zgemma, hence why I left them off the image but follow digicons advice if you want to try them.
  15. The Following User Says Thank You to martin035 For This Useful Post:
    digicon (1st December, 2015)
  16. #56
    Quote Originally Posted by martin035 View Post
    Openatv5.1 Backup Image with New improved Sky Skin, OTA update safe
    ? AutoBuoquetsMaker autoupdate daily @04:00
    ? Crossepg autoupdate daily @04:30
    ? Slyk1 Skin Thanks to the author Kiddac@TK forum **Many Thanks**
    ? SNP PIcons
    You must have 4gb USB drive or a larger USB drive permanently connected if you want to record programs and use the EPG, also the box connect by LAN to the internet.
    Due to this been on DK forums, I won?t give instructions on how to install any lines, all I?ll say is Blue button and second option down then ask google.
    https://www.dropbox.com/s/v22fphqzfbgjd3x/OpenAtv5.1%20Backup%20Image.zip?dl=0
    Install Backup image
    1. On PC format USB drive to FAT32 (quick)
    2. Unzip ?Openatv Backup image.zip? image
    3. Transfer ?zgemma? folder to root of USB drive
    4. Insert USB into SAT box (Rear USB port) and Power on.
    5. Once ?USB? displayed on Box a quick press and release ?standby? button on box, this will then display ?FLASH?
    6. Leave box, it should take 5 mins to flash then it will auto boot into BBC 1 HD
    Set Up USB Hard drive for Recording/Time shift and EPG storage
    1. Remove USB Boot drive and Insert your Storage USB drive
    2. Menu-setup-system-storage devices-Initialisation, Select your drive and format it
    3. Menu-setup-system-storage devices-Ext3 to Ext4, Select your drive and change filesystem
    4. Menu-info Panel-Plugins- Swap Manager, Blue to create 256mb, Green to activate, yellow to autostart
    AutoBuoquetsMaker (ABM) ie auto channel finder and favs maker
    ABM is already setup for the London Custom Area, with Adult channel/etc hidden .
    Setanta HD, Eurosport HD & HD2, RTE2HD, TV3HD are in the Favourite(TV) bouquet
    If you wish to change Sky UK area from London or to unhid/hid Adult/etc then;
    Menu-setup-service searching-ABM-Providers to the following;
    ? Sky UK Area- Scroll right to get ?your area? custom ie mine?s Scottish East Custom this will replace all none working HD channels with their working SD conterparts
    ? Menu-setup-service searching- ABM -Hide Bouquets tick/untick as required, green to save
    ? Menu-setup-service searching- ABM-Start Scan, this will add all the relevant channels for your area
    Setting up EPG
    EPG is set to update at 04:30 daily, but the initial download needs to be carried out
    1. Ensure Menu-Setup-Crossepg-Config ?storage location? is correct, if says ?internal? change to ?your usb drive name?
    2. Menu-Setup-Crossepg-Download Now and let the epg update
    3. Ensure Menu-Setup-EPG-settings ?EPG Location? is correct if says ?internal? scroll to ?/media/hdd?
    4. Menu-Setup-EPG-load/save ? save EPG
    **Remember for the EPG and Channel lists to Update daily the Zgemma needs to be in 'standby' at night**
    **If you prefer to turn the Zgemma fully off at night then Menu-Setup-Crossepg-config and set the update time to a time of your convenience during the day, else the EPG won't update'
    System image & Plugin updates
    menu-setup-software management-software update. Wait for the updates to be shown then press 'green' button, do this weekly or monthly your personal choice.
    **Thanks to toe471 for confirming that the image will also work on a Zgemma H1 combi box, however, this image is configured for a Satellite setup, it is unconfirmed whether the cable side of the H1 will work**
    Many thanks for this. I've just flashed my first zgemma box today and it looks the business. Easily done thanks to your clear instructions. Thanks again!
  17. The Following User Says Thank You to TheStretchedElf For This Useful Post:
    martin035 (3rd December, 2015)
  18. #57
    Apr 2012
    Will this work on the zgemma H2 box, the newer dvb-s, dvb-t and dvb-c version?
  19. #58
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by ginoworm View Post
    Not tested, so use at your own risk, a member has tested it on the H1 box and got the satellite side working but didn't try the cable side, so that is an unknown part of this image.
    My advice for h1 and h2 boxes is to build your own image following the guides on the forum as this will ensure you have the correct firmware/drivers for your zgemma.
    Firmware from the zgemma.tv website
  20. #59
    Apr 2012
    Worked perfect with my H2, what an amazing image, would love to get airplay working on it so i can stream NBC sports from my ipad?
  21. The Following User Says Thank You to ginoworm For This Useful Post:
    martin035 (5th December, 2015)
  22. #60
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Thanks for testing it and confirming that it works on a H2, can I ask have you tested it on the cable side to see if that works as well??
    There is an airplay plugin, but if memory serves me right it only works with older Apple products running a older versions of IOS, maybe start a new thread and ask the question I'm sure somebody on the forum will know.
