Results 1 to 2 of 2
    Default opel meriva 1.3cdti accelerate problem
    i have in service opel meriva 1.3 cdti
    ECU is marelli MJD602.M1
    accelerate normally to 3000rpm and then RPM gauge start to jump from 1500rpm to 3000rpm,and i hold same throttle
    i replace crankshaft sensor,check wiring,remove transmission i thought that flywheel teeth damaged,but everything is ok
    does somebody have similar problem?
    i suspect on ECU
    Most likely ecu fault m8, meriva always the same.
