ahmedadel (31st December, 2015)
Mike,
I have a VAG FVDI from a chinese seller and it works pretty good.. I do alot of 2006-2009 VW's and the only problems I have had is when I get an ECU that has a tune on it.. Have had a couple in the last month.. Called APR ( a tuner) and gave them the last six of the vin, they can't tell tell you what was done to the ecu, but they have been nice enough to say, yes, that car has a tune.. The customer was able to send the ecu's back to apr and they took out the blocking code and I was able to read the ecu and get the CP and pin.. The FVDI that I have works great if you have a key and are making another, if it is an all keys lost situation, you will probably have to read the ecu and then the program will search thru the bin and find the info.. I have a Micronas dongle with most softwares authorized, but if you go that route you have to have a Tango or other programmer to write the CP into the chip to preprogram the 48 can chip to learn to the car... The FVDI does this automaticly for you... and it guides you thru the process in wizard mode... As for diagnostics, the FVDI is pretty good, but I use VCDS to do most diag work.. Hope this helps,
Tim
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
Why does the PSA fvdi scramble the Johnson controls BSI on Peugeot 307
7.31sec@203.3mph
How to reset Toyota smart system (all key lost) by using FVDI?
Soft dog dongle is not free as written in their advertisement, it costs 100$, as I request to send locally on china to Shanghai city, two soft dogs and their answer 200$.
i try to open porsche section on fvdi but sw go down and close all. is possible to fix this problem??
ALL TUNING.
THE BEST OR NOTHING. THANKS + REPUTATION .
On the 999$ one ? ................or you have both ?
yess fvdi 999$
ALL TUNING.
Then I suggest you ask your supplier for assistance .....
i can fix the problem ore not , i dont now clone of the clone ore somthing else. all china tool is the same for me.
ALL TUNING.
hi tell me is possible to fix . i whait help from him thanks.
ALL TUNING.
all ok. seller enty on teamview and fix problem.
ALL TUNING.
