Page 138 of 183 FirstFirst ... 3888128133134135136137138139140141142143148 ... LastLast
Results 2,056 to 2,070 of 2732
  1. #2056
    Nov 2013
    Could someone post FVDI Nissan Airbag options screen, what can you do over there? Thanks
  2. #2057
    Quote Originally Posted by ClaudiuM View Post
    hey guys, can someone help me please. I have wrote 2 new keys on the bench for an 2011 VW Amarok and now the dash always displays 2-3. what have I done wrong, how can I make that go away?
    thank u
    I think you've only programmed 2 of 3 keys, it's still waiting on the third key.
  3. #2058
    Jul 2014
    good day to all of you
    My FVDI 2018 just stopped working today. it wont pick up on any usb port. i dont see any thing in the device manager.
    i tried on 3 diffrent pc's. it was working good for about 1 year now.
    any ideas on what could be the problem?
  4. #2059
    Junior Member MeMBraNe's Avatar
    Jun 2018
    Quote Originally Posted by saintgp View Post
    Have you tried with a different usb cable? also check the voltage on the usb cable if it is working. If its windows related, i can try assist over Teamviewer.
  5. #2060
    rob h's Avatar
    May 2011
    Fvdi 2014
    Everytime i start up vag V18.0 with keyreader attached, the program shuts off.
    Vag 21.0 starts fine with keyreader attached, here the MM7 tool does work proper.
    I run it on W7 32 and windows xp, no virus scan.
    Does anyone have the same problem, and a solution.
    I am considering buying a 2018 Fvdi with vag V18.0 and V24.o
  6. #2061
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Quote Originally Posted by rob h View Post
    Fvdi 2014
    Test............
    Press Thanks and Reputation
  7. The Following User Says Thank You to Kocta For This Useful Post:
    rob h (20th January, 2019)
  8. #2062
    doctore's Avatar
    Nov 2015
    Colorado Denver
    goo inside this folder and remove tag and post result
    C:\Program Files (x86)\Abrites Commander Software List\Common\TagKeyTool
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  9. The Following User Says Thank You to doctore For This Useful Post:
  10. #2063
    Kocta's Avatar
    Mar 2017
    Hi, first run AVDI rep. and then Fvdi.
  11. The Following User Says Thank You to Kocta For This Useful Post:
  12. #2064
    rob h's Avatar
    May 2011
    Perfect, thanks guys,
    I could not get the avdi rep to work.
    Have to check that out.
    So i removed the tag and tagkeytool from c folder.
    And it is fine now.
    Thank you very very much guys,
  13. #2065
    Jul 2014
    Quote Originally Posted by MeMBraNe View Post
    hi buddy
    yes i tried different cables.
    when it is plugged in with the blue tag dongle the lights on the dongle come on. windows does not recognize any thing plugged in.
    it think it a hardware issue
  14. #2066
    Jun 2018
    hi buddy
    Oh i see, so you are saying with the Fly OBD Tag connected the dongle lights up, but the light on the main unit does or does not, Does the key tool also light up? Have you tried starting windows in clean boot, to see if anything is interfering with the driver/usb.
  15. #2067
    Jun 2018
    Hi Guys
    I have been struggling for a few weeks with Audi A4 BCM2 key writing and still have not managed to find a solution as of yet. I use V18 as (V24 does not work on BCM2 it fails on decrypting), then passes reading transponder. When i get to prepare dealer key in V18, it fails at about 98% writing the key. The key is blank and is PCF7945AC 868Mhz and is a generic. I have soldered on a 501pcf, which improved reading keys all round. An original key reads perfectly, in the casing in Tag Tool. The generic i have to take out of the casing and basically hold the antenna right on the chip to actually read it. Could it be a dud key?
    I am considering purchasing KD-x2 as apposed to Tango or VVDI key tool as it looks like it has better growth - Any advise? Also would i need Orange 5 to dump the BCM2 as FVDI cannot BCM2 dump. Also IMMO5 does not work with VVDI2 1.2
  16. #2068
    Jan 2019
    vvdi prog where to buy better on eBay or official website http://www.vvdishop.com/ and what's the difference?
    how much have I watched the same prices
  17. #2069
    Jan 2019
    hey there , is it normal that fvdi cant get ride of my cp protection after i read eeprom 25640 on getaway by upa usb it says dump is from another module ??
  18. #2070
    Jan 2019
    waaauw flashed my getaway with vcp read it again with upa , started the procedure again with fvdi and it worked ... i got it on video it said succes with removing protection so i looked up to the dash and it was stil in safe mode ... what a waste of money and time
