I've been told stic 2018 is original?
Sent from my GT-I8190 using Tapatalk
hi,
yes the FVDI 2018 con not read the volvo you only can change the odometer !
me was told i ll have to wait for a new firmware
flyobd.com web site is not available
maybe stic company (www.flyobd.com) was dead.
Just an update to all in the future, i succeeded doing this with FVDI2018. Renewed key with kd-x2, modified antenna on programmer and bobs your uncle, coded the key without even taking the pcb out of the key shell. However, the China key was unable to be programmed (failed at 98%, even with antenna right on the chip) only an original that i renewed worked.
Ocin (11th May, 2019)
I tried with FVDI 2015, special function "Key learning", wizard mode, on Passat B6. It autodetected the pin, but I couldn't program a new key. When it is in adaptation process the immo symbol dissapear, recognize the key, but after the adaptation is finished the new key isn't recognised. Did I forget something ? Shall I try standard mode ?
Also, at first try, it delete also the original key, and after remake the entire procedure, the original key was learned again. It Could be a problem with the new key ?
VW Multivan 2.5 TDI 174cv 2007 year AKL done with FVDI 2014 v21.
fly boss gary said: fvdi source code is free for everybody in the world
VW Passat B6 read pin and learning key all done
Odoslané z môjho iPhone cez Tapatalk
Just got my FVDI 2014 but can not read BCM ECU or CLOCKS on my Corsa D am trying to retrieve the security code!
Any help would be great thanks
