Page 151 of 183 FirstFirst ... 51101141146147148149150151152153154155156161 ... LastLast
Results 2,251 to 2,265 of 2732
  1. #2251
    Mar 2018
    Quote Originally Posted by trinicolin View Post
    Read Tricore with KTAG or similar programmer. Would get immo data from eeprom within the tricore. Put eeprom file in key programmer and make key.
    Sent from my SM-G930F using Tapatalk
    Is it possible to be done using FVDI ?
    I was reading on the pdf the following:
    2.5.6 Special functions with “EDC17 and MED17 Boot” This function is dedicated to reading/writing of the EEPROM and flash memories of the EDC17/MED17 engine control units. Here not only VAG engine control units can be read, but also engine control units from other manufacturers (such as BMW, Opel, etc.). You need to:
  2. #2252
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    No................
    Press Thanks and Reputation
  3. The Following User Says Thank You to Kocta For This Useful Post:
    ecar19 (17th March, 2021)
  4. #2253
    Mar 2018
    Quote Originally Posted by Kocta View Post
    No................
    Would carprog do ?
  5. #2254
    Mar 2018
    Hello
    So I opened the ECU but the eeprom is an 2903Y how do I read this one ? No option on software for such eeprom ?
  6. #2255
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by kkdigger View Post
    Hello
    for any quality answer you should write a little bit about ecu....
    suzuki swift 2012 it´s not helpful for nobody...
    when you don´t know what kind of ecu you have post a photo from label...
    When I help you press Thanks and Reputation...
  7. The Following User Says Thank You to figani For This Useful Post:
    kkdigger (2nd June, 2019)
  8. #2256
    Aug 2016
    Tychy
    Hi lads ,
    just got a small problem with abrites 2015 .
    i reinstall system win7 64bit
    install abtires 2015 with loader 6.3 which working b4 i reinstall system
    now come up window with missing ch375dll.dll and mfc100.dll
    i have those 2 files in windows/system32 but still cant run program
    Only window quick loader comes up.. thats all
    I had as well problem with mfc110.dll but i fix up installing visual c++ 2012 update 4.
    Thx for solution
    solved !
    C:\ program files (x86)\abries \ patch
    in this folder which have c++ files to be installed .
    i install as well new version with loader 9.0
  9. #2257
    Mar 2018
    ecu 2.jpgecu 3.jpg Eeprom is a 2903Y
  10. #2258
    figani's Avatar
    Feb 2018
    It's tricore...
    So read it in boot mode...
    Or with new protocols without boot pin...
  11. The Following User Says Thank You to figani For This Useful Post:
  12. #2259
    Oct 2017
    can anyone please chip in here I had bought a fvdi unit at the beginning of the year it was the blue one and I read here how everyone is able to do many things on it but most of those functions doesn't work on mine so are there multiple clones and some are better than others or is mine a defective unit? I wanna be able to use it like most of the users on this thread. I've attached a picture I paid about 302$ for it on eBay.
    can anyone suggest a better clone and tell me if I got ripped off? thanks
    Sent from my SM-N950U using Tapatalk
  13. #2260
    Nov 2018
    Hello. Firstly sorry for my bad English. Recently I have bought FVDI 2014 from aliexpress for volvo dash flash reading and writing. I know that FVDI 2014 can do it perfectly. BUT. I've received non working FVDI. There was a circuit in the hardware between - and +. OK. I have found problem and fixed it, and now my FVDI 2014 is working, but only with k-line. I'd like to know, FVDI 2014 is too old for CAN bus, and should I purchase newer FVDI for CAN cars, or there is a problem with mine and FVDI 2014 should work with k-line and CAN protocols? Thanks in advance
  14. #2261
    Kocta's Avatar
    Mar 2017
    Quote Originally Posted by Dewagg View Post
    FVDI can - K line, can, UDs. You got the bad Fvdi.
  15. #2262
    Kocta's Avatar
    Mar 2017
    Quote Originally Posted by esx503 View Post
    Fvdi 2018 - shit.
  16. The Following User Says Thank You to Kocta For This Useful Post:
    esx503 (28th June, 2019)
  17. #2263
    Oct 2017
    Fvdi 2018 - shit.
    I figured. can you suggest a good quality clone please.
  18. #2264
    lion0304's Avatar
    Oct 2014
    Mine from fvdiobd.com 2014 and 2018 OK
  19. #2265
    Kocta's Avatar
    Mar 2017
    Fvdi 2014 - Ok
    Fvdi 2018 - Shit
