Page 152 of 183 FirstFirst ... 52102142147148149150151152153154155156157162 ... LastLast
Results 2,266 to 2,280 of 2732
  1. #2266
    May 2019
    Germany NRW
    Hi Guys,
    i have a prob with my flyobd fvdi 2015 i change the PC and now it write every time device not opened..... i look all videos because no reason...
    can one pls help my per Teamwiever
    regards
  2. #2267
    Oct 2017
    ok thank you all for your input
    Sent from my SM-N950U using Tapatalk
  3. #2268
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by honkytonky View Post
    Hi Guys,
    regards
    It should be a driver problem...
    Re install drivers...
    When I help you press Thanks and Reputation...
  4. #2269
    Feb 2018
    Opel Astra H 2006 Security code read success with FVDI 2014
  5. The Following User Says Thank You to BeatsByMe For This Useful Post:
    mexanico1971 (12th July, 2019)
  6. #2270
    Oct 2018
    Northern Ireland
    2005 Vauxhall Vivario failed to programme new key
  7. #2271
    Dec 2015
    Default ***** FVDI Technical Support *****
    Dear mates have mercedes with ezs motorolla mask number 0 D69J when i try to make key by dump fvdi freeze and software crashes is it possible to make chip 7935 on this device or useless AVDI can do and have made already chip but wanted to know if FVDI is capable or not thanks for ur help
    NO ADVERTISING PLEASE
  8. #2272
    Jul 2013
    Fvdi cant make key for merc with that mask,.
  9. The Following User Says Thank You to Nikola1309 For This Useful Post:
    Nassreddine84 (13th July, 2019)
  10. #2273
    Dec 2015
    Quote Originally Posted by Nikola1309 View Post
    Ok thanks
  11. #2274
    Feb 2017
    Hi can someone with this box please help me get PIN code from the Key Programming Help Menu for 2010 Mitsubishi Galant Fortis. Its a CY3A chassis.
    If i can get a screenshot of the PIN code page would be great.
    Please help it will be greatly appreciated.
    dX
  12. #2275
    ibratex's Avatar
    Jul 2015
    angola
    hello experts , that might sound weird in here
    i have avdi unit , is it possible to firmware flash it then use the hardware on fvdi software 2014 full 18?????
    since chinese hardware less stable maybe marriage of original hardware and fake software will make a superman
  13. #2276
    Oct 2018
    Hello.
    I have some problem with my FVDI 2018 by Fly(Stic).
    when I try to renew 7g tronic :
    1. Didnt save the new SCN number in donors plate. (siemens 7332, 2 different plates)
    2. When I make a virgin - flash when it comes 100%, an error appears - Failed to renew.
    whats wrong?
    thanks.
    All the latest software downloaded from Flyobd.com
  14. #2277
    Jun 2016
    Breaking news!
    FVDI fly is changed to SVCI.
  15. #2278
    newone's Avatar
    Oct 2016
    Hello,i have fvdi 2014,i had it installed in a xp laptop but now i tryed on a win7 64,had many issues to try to run but in the end managed to make it run without installing the algo client folder,program seems to run ok without crashing or other issues,can someone clarify if algoclient is nececcary for any part of the program?
    thanks in advance
  16. #2279
    Jan 2019
    Somewhere between Continents
    I hope someone can help me out on this:
    I have the FVDI 2018 and I’m trying to program a key for a VW Jetta type model, but I can’t find what I’m doing wrong... (in other words I don't know exactly how to do it).
    The car, is a Mexican model car, and it might have different equipment from other countries.
    This car here is called "Jetta Clasico" and it’s an early 2012 model so it might actually be from 2011 but sold in 2012.
    For what i tried to read with this tool the immobilizer / dash information that i get is: kombi+wegfahrsp vdo v75 and it gives me protocol "KWP1281" (K-Line) but when i try to read, connect or program the key nothing happens and I’m stuck with this.
    I’m new at this and I’m learning about the software, equipment, tools, etc. and I was hopping that some Good Soul could help me out with this.
    For this car I bought the Original Key Fob "5K0 837 202 AE" with a Virgin ID48 chip.
    Can anyone help me out with the procedure (tutorial or video or any info) on how to program this key?
    How can I know if the chip I have is really the correct one?
    Do i need to remove the dash for programming? (because in trying to do this over OBD2)
    Thanks for the Support guys.
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  17. #2280
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Quote Originally Posted by boxsport View Post
    I have the FVDI 2018 and I知 trying to program a key for a VW Jetta type model, but I can稚 find what I知 doing wrong... (in other words I don't know exactly how to do it).
    This car here is called "Jetta Clasico" and it痴 an early 2012 model so it might actually be from 2011 but sold in 2012.
    For what i tried to read with this tool the immobilizer / dash information that i get is: kombi+wegfahrsp vdo v75 and it gives me protocol "KWP1281" (K-Line) but when i try to read, connect or program the key nothing happens and I知 stuck with this.
    I知 new at this and I知 learning about the software, equipment, tools, etc. and I was hopping that some Good Soul could help me out with this.
    https://youtu.be/gO7SRx-BuHU
    Press Thanks and Reputation
  18. The Following User Says Thank You to Kocta For This Useful Post:
    boxsport (23rd August, 2019)
