Page 153 of 183 FirstFirst ... 53103143148149150151152153154155156157158163 ... LastLast
Results 2,281 to 2,295 of 2732
  1. #2281
    Feb 2019
    Chester UK
    I have FVDI V2018 - ID: EO1389
    I have never managed to get it to work. When I open the program I get: Connect to server, then, Cannot connect to server, then,: this device has been deactivated.
    when I hit ok, I get a box that says:spawn app failed: 1
    Any ideas how I can get it working?
    I contacted the support and they ignored me so need help if possible to get it to open and work.
  2. #2282
    Jan 2019
    Somewhere between Continents
    Quote Originally Posted by Kocta View Post
    Thanks for the Video, but this car model is not CAN Line.
    I tried to read CAN and it doesnt work....
    Someone told me that i need to use FVDI V21, so i need to test again and see if it works...
    It seems that this car / Immo model dosent use the 7th byte programming (Component Security) that newer models use...
    I still cant program this key, so i hope today i can test again...
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  3. #2283
    Jan 2019
    Quote Originally Posted by AA247 View Post
    I also had something similar happend once to me.
    I tried to install Foftware Loader V3.0 and then V4.0.
    I also tried to open software without internet and it worked...
    But for what i saw over internet, it seems that it might be also related to "Connection Order" in PC, and drivers related....
  4. #2284
    Oct 2015
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  5. #2285
    Junior Member MeMBraNe's Avatar
    Jun 2018
    Did you manage to come right?
  6. #2286
    Jan 2019
    hello guys,
    so i´m trying to program some keys for a 2006 Dodge Ram SRT10 and i read that some Chrysler systems need a J1820 Adapter.
    Can anyone tell me what is the function of this?
    i have the FVDI 2018 (china) with several adapters but this one i´m pretty sure it doesn't came.
    Are there any diagrams over the internet for this adapter?
    When i try to read the SKIM on this truck it doesn't give me any info (in new ones i had no problem).
    I had once communications with the ECU, but now i can get any info at all on this truck,
    Any help i would appreciate.
  7. #2287
    venceslau's Avatar
    Dec 2018
    North America
    Hello all, I think I bricked my FVDI 2015 (STIC FlyOBD).
    SoftDog blinks both red/green led simultaneously and computer isn't detecting anything when I plug in USB.
    Here's exactly what happened:
    -Loaded Quickloader (7.1)
    -Selected BMW Tools (accidentally)
    -Clicked Cancel while the message "Connecting to interface, please wait..." was up
    -Device Died after this and device worked perfectly before
    Symptoms are exactly as described here: http://blog.obdii365.com/2018/07/05/...link-solution/
    However this post seems to be for Quickloader 6.3 but my setup is running Quickloader 7.1
    Is there any hope of saving this? Would really appreciate some help.
  8. #2288
    Jun 2019
    Tried to do DAF truck 2007 today but had some problems fitting obdplug into socket... it seems halfway there is some plastic bits so the normal plug wont fit... does anyone has a suggestion for this?
  9. #2289
    Aug 2013
    Macedonia
    remove obd connector from truck cut off 2 plastic nutch from connector and you are ready to go : )
  10. #2290
    Jun 2019
    Quote Originally Posted by nenadgorgi View Post
    Yeah i thought about it but dont want to mess with their plug so bought a small extension that i modified so problem solved.
    but fvdi can only do older DAF trucks and i was interrested if zed full or AD100 pro can do newer Trucks anybody care to share?
  11. #2291
    Jan 2019
    Hi guys, it's possible to update FVDI 2015 to 2018?
  12. #2292
    electronistul21's Avatar
    Nov 2011
    galati,romania
    Not ,my friend,not can make update to 2018.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  13. #2293
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Quote Originally Posted by xyz001 View Post
    there are 2 kinds fvdi 2018, fly fvdi 2018 and stic fvdi 2018.
    Attachment 606053
    Silly question what FVDI tool will members recommend to buy today ?
    'If I helped, please click Thanks +Reputation.. !'
  14. #2294
    Mar 2019
    Scandinavia
    Quote Originally Posted by rtbdiagnostic View Post
    Fly /STIC is original clone of AVDI....
    learning by doing, learning by experience... please thx is I helped you
  15. The Following User Says Thank You to Willinickersen For This Useful Post:
    rtbdiagnostic (23rd September, 2019)
  16. #2295
    Original clone - that is very nice expression.
