Buy new FVDI 2014 old PCB
Press Thanks and Reputation
Hello guys,
I wanted ro know if there is anyway that the FVDI 2018 can work as a j2534 passthrough...
I read that the original one can work, by using a "driver" (or additional adapter) but i wanted to know if anyone has any info on how would this work with the clone...
Hi guys,
Can anybody please tell which repairs for Mercedes SBC are possible with fvdi tool? Screenshot would be awesome.
Anybody know if reading eeprom and writing eeprom is possible?
I'm stuck with a C235 Fault code on a w211
Hi, I have buyed fvdi 2018 but when I try to write transponder it's show me can't read MEGAMOS ID48. I have tried to read old key same error.
Col19 (2nd February, 2021)
The TAG key "ring" is a little bit tricky. Try change position of the key / transponder in ring. Sometimes reposition key / transponder in reader ring works. Do you use autodetect to read? Are you sure that transponder is megamos 48? Autodetect sometimes dont work properly, you must choose exact transponder type.
As mentioned, evrytime o have key reading issue i move the key in the ring little bit. Also transponder sometimes is better to have it on theside inszead of middle of the ring
someone helps me with fvdi 2019 I don't know if buying it continues with the bsi that breaks them
FVDI Suzuki Swift 2012+ Key Less Programming - All keys lost
Can we program a key with FVDI for the keyless Suzuki Swift 2012+
There is no Suzuki on the list - Is there an Alternative ?
boxsport (2nd December, 2019)
I need ftdi 2014. THX
Svci 2020 is out boys you are all far behind
drdahmani2 (15th December, 2019)
