Page 160 of 183 FirstFirst ... 60110150155156157158159160161162163164165170 ... LastLast
Results 2,386 to 2,400 of 2733
  1. #2386
    Talleresmalaga's Avatar
    Nov 2017
    Espaņa
    Quote Originally Posted by eimantuxx View Post
    FVDI 2018 VOLVO DIM dash read eeprom/flash ok? to 2008
    From my experience with FVDI 2018, you can change mileage and read flash, but it does not allow to write flash, the clone limits the size of the file, only writes part of it and, instrument panel dies
    Cheers
    If help is useful thanks+rep
  2. The Following User Says Thank You to Talleresmalaga For This Useful Post:
    Faraday (12th September, 2020)
  3. #2387
    I've bought SVCI 2020 and tried to read eeprom from VW EDC16U1 ecu and EDC15P+ ecu, but with NO success. The SVCI 2020 it does not identify the EDC16U1 ecu. With my old FVDI 2014 I cand read edc16u1.
    Is there a problem reading VAG ECU with SVCI 2020?
    Sent from my S90_Apex using Tapatalk
  4. #2388
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by alladdin205 View Post
    Which its the diferenc between fvdi 2018 and svci 2020 does the special function work in svci ?
    Sent from my SM-J415F using Tapatalk
  5. #2389
    Works on old version off software....on new added versionof sotware does not work...on mine does not work at all
  6. #2390
    Oct 2012
    World
    I have STIC FVDI II. Didn't use it for some time. Now it says unregistered or license expired 2018.05.11.
    What do i need to do now?
  7. #2391
    Oct 2012
    World
    I needed to update to obd-quickloader v5.12 - which is at this time the newest version.
    Now it works again. Hope that helps anybody else.
  8. The Following User Says Thank You to Smallblock454 For This Useful Post:
    fixanycar (24th June, 2020)
  9. #2392
    Oct 2012
    World
    Next problem: TAG generates AVDI error 2.
  10. #2393
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    maybe somenone tried before with fvdi...
    Fiat Ducato 2007 to read eeprom dump from bsm by obd...?
    Magnetti Marelli is it...
  11. #2394
    Dec 2015
    Is it possible to get radio code by fvdi on touareg 2007
    Thank u
    NO ADVERTISING PLEASE
  12. #2395
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    No, I needed a carprog.
    Press Thanks and Reputation
  13. #2396
    Dec 2015
    Need remove and read eeprom on bench?
  14. #2397
    Member technoparc's Avatar
    Sep 2018
    SPAIN
    Hello Friend how are you. I have VVDI2 + VAG helper. There are doubts. I need help. Thank you
  15. #2398
    electronistul21's Avatar
    Nov 2011
    galati,romania
    Quote Originally Posted by Nassreddine84 View Post
    Touareg 2007 have MFD2 navigation.In this unit code is stored in eprom from FIS.Carprog read eprom directly with SCL SDA,but FVDI (SVCI) not can this
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  16. The Following User Says Thank You to electronistul21 For This Useful Post:
    Col19 (2nd February, 2021)
  17. #2399
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by electronistul21 View Post
    Which version of carprog?
  18. #2400
    Oktawian's Avatar
    Sep 2016
    fvdi2018 - vvdi2 - can anyone connect to any k-line car by obd ? Read dash canal 17 ?
