Page 2 of 183 FirstFirst 12345671252102 ... LastLast
Results 16 to 30 of 2742
  1. #16
    Oct 2012
    for peugeot and citroen 2007 up the abrites psa clone can read - write bsi....45 minutes with charger of batterie,lights on and wipes on
  2. The Following 2 Users Say Thank You to betrescudan For This Useful Post:
    ahmedadel (31st December, 2015), kamolsf (13th May, 2018)
  3. #17
    Siham's Avatar
    Jul 2014
    Hi Gwee ,
    yes i told i am new in car because its only 5 month i started , but i know how read bsi or uch and bcm/kessy for key adding or virginise bsi and MB/bmw keys, for 8 month i worked in a garage as aprendist and after my boss gone garage closed so i tried to start something by myself.
    I was just asking why fvdi corrupt data in bcm ,no more , and i know i am working with car and not nitendo ,many people damaged car with fvdi i'am not the alone.
    Siham
  4. The Following User Says Thank You to Siham For This Useful Post:
  5. #18
    Oct 2012
    Siham...don.t worry my friend...and welcome on DK...we need gents like you
  6. The Following User Says Thank You to betrescudan For This Useful Post:
  7. #19
    Siham's Avatar
    Jul 2014
    Hi Gwee ,
    Ok no problem , and thank you for explaining me toyota fvdi is ok , i do not know this things.
    yes i'am from south africa and now leave between italy and moroco , my father was half south african and half from moroco and my mum is from half somalian and half italian.
    I'am a good shake of origin.
    You ask me if I'am from south africa about my name ?
  8. The Following User Says Thank You to Siham For This Useful Post:
  9. #20
    Siham's Avatar
    Jul 2014
    You are a great man on a exceptional forum.
    Thank you for your time and work.
    Hope to learn from you.
  10. The Following User Says Thank You to Siham For This Useful Post:
  11. #21
    super jumbe's Avatar
    Livingstone
    gwee has already told you to report and fly will come and try to help you all out, I do not think you lot need help but just to cause agro, put your question and you will get help.
  12. The Following User Says Thank You to super jumbe For This Useful Post:
  13. #22
    Quote Originally Posted by gwee View Post
    you have FVDI- VAG ??
    i don't think so otherwise you should know that there is option to choose different version !!
    keep changing SW / FW
    if you are not FVDI user, please read post #1
    well FYI I am fvdi user
    I have BMW fvdi and have use of VAG fvdi, admittedly both units are still running original firmware/software because we haven't sent the units back to be patched/upgraded, hence why we don't get the option to use different software.
    If vag user with latest PCB ( or you with your full test unit) has that option then furry muff.
  14. The Following User Says Thank You to u.s For This Useful Post:
  15. #23
    VAG FVDI package, using Tag key tool doesn't have the option to find CS from EPROM dump for Passat 3C
  16. The Following User Says Thank You to u.s For This Useful Post:
  17. #24
    Moderator
    PremierD's Avatar
    Jun 2009
    Lets keep to the thread title please people
  18. The Following 2 Users Say Thank You to PremierD For This Useful Post:
    ahmedadel (31st December, 2015), Stelaras26 (29th December, 2017)
  19. #25
    smayer's Avatar
    Jan 2012
    smayer you are a "persona non grata" to fly and not deserves response
  20. The Following User Says Thank You to smayer For This Useful Post:
  21. #26
    smayer's Avatar
    Jan 2012
    Originally Posted by insomnia2009
    sprinter 2007 esl steering lock did not read true kline so far tool is a disaster
    Quote Originally Posted by zhumerchant View Post
    Thanks for using FVDI.
    Please send log files to us. Log file path: My documents\ABRITES software for ID 17118A\Mercedes.
    My skype ID: zhumerchant
    email address:
    Once fly company don?t know nathing about cars i do the right answer, FVDI or AVDI can?t read this esl with NEC inside!!!
  22. The Following User Says Thank You to smayer For This Useful Post:
  23. #27
    zhumerchant's Avatar
    ask them to answer this tomorrow
    you mean EEPROM 95320?
  24. The Following User Says Thank You to zhumerchant For This Useful Post:
  25. #28
    Yes, comfort module EPROM
  26. The Following User Says Thank You to u.s For This Useful Post:
  27. #29
    I purchase renault fvdi. It will program renault megane/scenic keycards before 2007. When I try a scenic ph2 x84.2007 reg it will not extract pin code,so it will not program keycard. I was currently using 5.2 version,but update it to 5.4 ,does this version have problem. Can I change back to version 5.2 thanks
  28. The Following User Says Thank You to radiosolutions For This Useful Post:
  29. #30
    Quote Originally Posted by radiosolutions View Post
    well I think the original still does not do 2007+ so hows the clone going to work??
  30. The Following User Says Thank You to paul_12345 For This Useful Post:
