Galleto V54// carprog v4.7 dongle// Diagbox//vass 5054// x- prog-v50 dongle//rosfar r260- fiat scanner/ svdi vag-bmw-/ fvdi full// digiprog 3// digimaster 2// Renault can clip// vag com // bmw inpa// pasoft 1.4// autocom // Tecnomotor // bmw carsoft 6.5// mercedes carsoft 7.4 // Opel com //
[Quote = salamandra; 2425572]. Ese mismome
. releer el pin, te despertar?s BSI y le dar? el c?digo de
un saludo![]()
Enviado desde mi iPhone con Tapatalk [/ quote ]
sure friend iwas to pay 800Euros with peugeot 308 and bsi jonhson
That is very helpful information.
http://www.fvdiobd.com/fvdi-abrites-...-can-t-do.html
After 2 months whaiting Received today new interface V2015 with softdog.
After several hours strugling i can say:
No brands sofware actualisation.
Fly add more hardware and software conclusion add more bugs.
Before my interface don?t work, now don?t work.
After change ftdi driver?s it?s working.
Time o test in cars and see results.
I have had a bad experience with Fly ....
O wow i sent mind 2 weeks ago maybe ill let them keep it
Sent from my GT-I9505 using Tapatalk
"original" FVDI can do many functions without any prolem with MB Commander.
W221 Correction ok
W221 Dashboard eeprom reading ok
W221 CGW EEPROM and Flash reading ok
W211 ZGW EEPROM ok
W169 ZGW EEPROM ok
W168 correction and Assyst data correction ok
W168 170 CDI ECU eprom reading ok
W203 200 CDI ECU eprom reading ok
W203 Assyst data correcting ok OBD
Smart 450 key learning ok
Smart 451 km correction and Assyst data via OBD ok
Is this tested yourself with fvdi 2015 thanks for the info
I have re read pincode same problem !!!!
For all don't anyone try to read Johnson controls with FVDI
try to connect this BSI on the table to FVDI.
what the pinout connections to work in this table BSI ?? or you read eep.?
excuse my English, is the best.
I connect FVDI on table,works ok
on car failed...
