Here is the dumps for psa 208 2013 bsi eeprom 95256 & dash eeprom 95320BSI & DASH 208 2013 HDI.rar
Everything will be back in order - All my respects to DK's members.
May you give us the link ...............No mate ... he won't .. its for the clone anyway .
I have a probem with bcm2 increase key audi s5 2009 with fvdi old.
Tool connect successfuly with bcm and read it correctly, display number of keys etc.
The problem is when i try to make dealer key. I have 3 different blank bcm2 keys type, two from china and one original abritus blank bcm2 pcb from online shop.
Each time i try to make dealer key, it says no key detected in the tag programmer.
Also, for testing purposes i run the tag tool. Original key from car gets identified correctly but the blank keys not - i'm not sure if they should get identified as long as they are blank or should they get identified only after successfull programming to car.
I can code original key back to car no problem. I just cannot make blank keys dealer key.
I tried teamviewer with fvdi and they said keys must be bad - its hard for me to accept this verdict as i have 3 different keys type including original.
Anyone else have this experience?
Chinese tag programmer is bad. i have same situation, but now i use orginal tag programmer from orginal avdi and all work ok
@micromax
you say that using the (original TAG antenna) in FVDI clone, work OK?
or you're using the original AVDI?![]()
Micromax You're the man. I also have original avdi and the tag antenna to my amazement work with it and i could now code my bcm2 key no problem.
Dzieki
Just to make clear, i used original tag antenna with old fvdi - obviously.
what is new in Firmware 1 version: 2.18 ?
If that's what is on their site then that's what it is mate ..![]()
If use original Avdi antenna with fvdi firmware will not block antenna?
