Page 1 of 176 1234561151101 ... LastLast
Results 1 to 15 of 2740
Hybrid View
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    Default ***** FVDI Technical Support *****
    First thing which one need to be fixed:
    http://www.digital-kaos.co.uk/forums...one-km-373755/
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
  2. The Following 3 Users Say Thank You to Saulius Saulius For This Useful Post:
    ahmedadel (31st December, 2015), elas00 (1st December, 2021), YASS59 (3rd August, 2020)
  3. #2
    Jan 2011
    sprinter 2007 esl steering lock did not read true kline so far tool is a disaster
  4. The Following 2 Users Say Thank You to insomnia2009 For This Useful Post:
    ahmedadel (31st December, 2015), Rodolph (26th February, 2019)
  5. #3
    zhumerchant's Avatar
    Apr 2010
    Quote Originally Posted by insomnia2009 View Post
    Thanks for using FVDI.
    Please send log files to us. Log file path: My documents\ABRITES software for ID 17118A\Mercedes.
  6. The Following User Says Thank You to zhumerchant For This Useful Post:
  7. #4
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by zhumerchant View Post
    My skype ID: zhumerchant
    email address:
    Once fly company don?t know nathing about cars i do the right answer, FVDI or AVDI can?t read this esl with NEC inside!!!
  8. The Following User Says Thank You to smayer For This Useful Post:
  9. #5
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    i have a fdvi ID F01114 with Mazda /Ford V4.9+Tag V6.1+H&K V2.1 but the special function for programming keys , injector and adopting new units is not working , it only saying failed
  10. The Following 2 Users Say Thank You to autocheck For This Useful Post:
  11. #6
    Apr 2010
    Quote Originally Posted by autocheck View Post
    These bugs is caused by original AVDI. For original AVDI has many bugs at Ford/Mazda commander.
  12. The Following User Says Thank You to zhumerchant For This Useful Post:
  13. #7
    one question why you then clone the original avdi sw when it is full of bugs, why you not make your own sw which is much more better and 100% working.
  14. The Following User Says Thank You to chriskross For This Useful Post:
  15. #8
    Jan 2011
    any reports on this i have mind sent back for softdog going to try full for 6 months anyone get theres back curious is working well
  16. #9
    Jun 2013
    Hello fellow; que tal? recently acquired one full VFDI. my experience will be numbered.
    mercedes w212-in odometer adjustment stays reset the Getaway. you should go to official dealer and make a scn. and not reset odometer.
    - Fiat Punto 2010/2009/2008. odometer adjustment does not work either takes eprom read 1.3 mj.
    - Ford focus 2007 makes no adjustment odometro-
    -BMW e / 87 Series 1 does not communicate with any module.
    -BMW x3 2009 does not communicate with almost any module except motor.
    corsa D -opel not adjust odometer or read eprom 1.3 mj
    -works well with almost all new vehicles.
    I wish I have if someone could help me in ques odometer adjustment of physical keys, and to perform an upgrade key?
    thanks for your help, and if I can help in something I'm here. ;-)
    Deshacer cambios
  17. #10
    Aug 2013
    Spain
    Hello.
    I have a FVDI with the ID : F09461 for Fiat, and another one with the ID: F07407 with all the software.
    With both of them FVDI I can't read the BCM siemens and nor the BCM marelli. I can only read the BCM delphi (93C66).
    - With the psa software I can't read the security code and I can't work with the BSI Exchange neither.
    - With the VAG software while I'm programming the keys by wizard mode the software has locked two cluster of Seat Leon CAN bus system with micronas MCU into the cluster.
    If you can help me with these problem I will be very grateful with you.
    Thanks in advance.
    Cars&Keys.
  18. #11
    Jun 2013
    If it is Fly Company Ltd. FVDI full 4500USD.
    Which you already pay good money for, you can update it with "Softdog" and FVDI 2015. You will get latest V6.3 software.
    Need to send it back to Fly Company Ltd.
    Costs: About 95 USD for Softdog, plus shipping of only the circuit board from the FVDI box to China.
    Freight from China is free.
    Should be free software updates forever.
    And probably some support on these cases.
    If copy or none updatable. There are some people on forums which offer other solutions. So you can get the latest updates.
  19. #12
    Aug 2014
    Quote Originally Posted by mike john View Post
    I am going to buy a fvdi vag, but some people told me fvdi can only do diagnosis function well, for some other function not good, any ideas?
    I bought a SVDI VAG commander:[IMG]file:///C:\DOCUME~1\echo\LOCALS~1\Temp\%W@GJ$ACOF(TYDYECOK VDYB.png[/IMG]http://www.obdtool.co.uk/wholesale/svdi-vw-audi-vehicle-diagnostic-interface.html, it do diagnosis, immo and key match well, and it much cheaper than FVDI VAG.
  20. The Following User Says Thank You to Daniel Greyson For This Useful Post:
  21. #13
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by Daniel Greyson View Post
    101% you are Chinese seller
    you think we are stupid like you?
  22. The Following User Says Thank You to gwee For This Useful Post:
  23. #14
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    WHERE CAN I GET THE J1850 ADAPTER FOR EARLIER MODELS ?
  24. The Following 2 Users Say Thank You to autocheck For This Useful Post:
    ahmedadel (31st December, 2015), Jobeso66 (11th October, 2017)
  25. #15
    Maartinj's Avatar
    Nov 2010
    Poland
    ECU adaptation doesnt work (EDC16, did not try EDC17 but gues also fail) . Work few time when one of tech support was online. Now - doesnt
    v21 - when Micronas cluster read - show " No millage in DSG module" , must use V18 to read Micronas cluster
    Immo 5th - missing licence
  26. The Following 3 Users Say Thank You to Maartinj For This Useful Post:
    ahmedadel (31st December, 2015), Dani375 (3rd December, 2018), Qaso0ombh96 (26th October, 2020)
