Page 85 of 183 FirstFirst ... 3575808182838485868788899095135 ... LastLast
Results 1,261 to 1,275 of 2742
  1. #1261
    Jul 2014
    2016-8-24 V1.5 Released:
    1. VAG Generation 5 Immobilizer Function:(
    1.Read BCM2 Immobilizer Data By OBDII;
    2.Generate dealers keys and key learning;
    3.Open/close Immobilizer Horn;
    4.Recover Emergency data(Power down in the process of reading immobilizer data);
    5.Check the new PCF7945AC (HitagExt VAG);
    Note 1:
    No.1 List of models:
    1. Audi A4;
    2. Audi A5;
    3. Audi Q5 2007+;
    Note 2:
    FLY OBD Terminator Software Function.
  2. #1262
    Jul 2014
    JLR SDD Coded Access Password for Locked Functions:
    1.Jaguar:
    CCF EDITOR
    ODO APP (X150)
    ODO APP (X250)
    ODO APP (X351)
    SOFTWARE DOWNLOAD
    VID BLOCK EDITOR
    VIN BYPASS
    RECOVER KEYS (X351)
    2.Land Rover:
    CCF EDITOR
    ODO APP (L316))
    ERASE KEYS (L322)
    ODO APP (L322)
    RECOVER KEYS (L322)
    OPTION 8
    SOFTWARE DOWNLOAD
  3. The Following User Says Thank You to totoo For This Useful Post:
    ibratex (24th August, 2016)
  4. #1263
    Jul 2014
  5. The Following User Says Thank You to totoo For This Useful Post:
  6. #1264
    Feb 2010
    South Africa
    Is there a Passthru driver for fvdi? ,regards
    Do what you can with what you have .
  7. #1265
    Jul 2014
    Quote Originally Posted by ecufix View Post
    Please contact fly support engineers.
  8. The Following User Says Thank You to totoo For This Useful Post:
    ecufix (30th August, 2016)
  9. #1266
    Top Poster + randomlog's Avatar
    May 2010
    Argentina
    hi, im from mercosur ( argentina ) can you tell me compatibility for our models ?.
    like VW GOL, FIAT UNO, CHEVROLET SPARK , ONIX , PRISMA , CLASSIC , etc ?
    Admin of Audi Forum Argentina.
  10. #1267
    Sep 2011
    hi
    Who knows
    FVDI for Renault
    is ok?
  11. The Following User Says Thank You to keyantic For This Useful Post:
    dyzio (31st August, 2016)
  12. #1268
    Jul 2014
    Quote Originally Posted by keyantic View Post
    hi
    Who knows
    FVDI for Renault
    is ok?
    ABRITES Commander for Renault is professional software mainly for programming the new key/card of Renault vehicles.
    NO NEED FROM A PIN CODE
    Functions :
    Connecting with all electronic control modules in the vehicle. Working by K and CAN bus diagnostic connection.
    For all electronic control units reading identification data
    For all electronic control units read and clear error (DTCs)
    For all electronic control units live data (measured values)
    For all electronic control units coding/configuration
    For all electronic control units actuator tests
    Airbag crash data clear Dacia Logan/Duster by OBDII
    Program ID in UCH module
    Mileage recalibration in Instrument cluster (JC) - Laguna III, Megane III, Fluence, Master III, Scenic III, Scenic/Modus (2003-2004), Clio II, Kango by OBDII
    Mileage Recalibration by OBDII - Renault Megane II, Renault Clio III 2005 year (Visteon instrument cluster), Renault Megane II 2004 - 2005 year (JC instrument cluster)
    Mileage recalibration for Renault Clio/Kango/Meganne with HC908 JAEGER by dash connector
    Key programming function / pin code reading :
    - Meganne II X84 2003-2006
    - Renault Megane II Ph2 X84 2007+
    - Renault Megane III X95 2009+
    - Renault Megane III X95 2011+ **
    - Renault Scenic II X64 2003+
    - Renault Scenic II Ph2 X64 2007+
    - Renault Scenic III X95 2009+
    - Renault Scenic III X95 2011+ **
    - Renault Laguna II X56 2000-2005
    - Renault Laguna II Ph2 X74 2005-2007
    - Renault Laguna III X91 2007+
    - Renault Valsatis X73 2002+
    - Renault Valsatis Ph2 X73 2006+
    - Renault Espace IV X81 2003-2006
    - Renault Espace IV Ph2 X81 2006+
    - Renault Master Ph2 X70 2002-2006
    - Renault Master Ph3 X70 2007+
    - Renault Traffic II X83 2002-2006
    - Renault Traffic II Ph2 X83 2007+
    - Renault Kango MUX Ph2 X76 2002-2007
    - Renault Kango X61 2008+
    - Renault Clio II Ph2/3 X65 2002-2006
    - Renault Clio Symbol
    - Renault Clio Symbol 2010+ (BCM JC)*
    - Renault Clio Thalia
    - Renault Clio Campus
    - Renault Clio Sedan
    - Renault Clio Classic
    - Renault Clio III 2005+
    - Renault Clio III with key card
    - Renault Modus 2004+
    - Renault Grand Modus 2008+
    - Renault Master III X62 2010+
    - Dacia Duster 2010+ (BCM JC) *
    - Dacia Logan X90 2004-2008
    - Dacia Logan Ph2 X90 2008+
    - Dacia Logan 2010+ (BCM JC) *
    - Dacia Sandero B90 2008+
    - Dacia Sandero 2010+ (BCM JC) *
    - Dacia Solenza 2003-2005
    - Renault-Samsung SM3 2006+
    - Renault-Samsung QM5
    - Renault-Samsung SM5
    - Renault Fluence 2009+ *
    - Renault Fluence (BCM immobilizer) 2009+
    - Renault Fluence (BCM immobilizer) 2011+ **
    - Renault Twingo Ph2 X06 2002-2007
    - Renault Twingo II X44 2007+
    - Opel Vivaro 2002-2006
    - Opel Vivaro Ph2 2007+
    - Opel Movano Ph2 2002-2006
    - Opel Movano Ph3 2007+
    - Opel Movano B 2010+
    - Nissan Primestar Ph2 2002-2006
    - Nissan Primestar Ph3 2007+
    - Nissan Platina 2002-2008
    - Renault Latitude
    - Renault Koleos
    * Programmer is also needed - ZN001 - TAG programmer
    ** ABPROG (ZN030) is also needed
  13. #1269
    micromax's Avatar
    Dec 2009
    South Poland
    keyantic ask about FVDI , we know that AVDI work with Renault.
    ABPROG work with FVDI now ? graet !!
  14. The Following User Says Thank You to micromax For This Useful Post:
    keyantic (1st September, 2016)
  15. #1270
    Nov 2009
    stupid and compare avdi and fvdi
    fvdi fly work max 10%
  16. #1271
    Jul 2014
    Quote Originally Posted by koyot View Post
    1. fvdi 2 support Honda HDS V3.101.015 , can do all honda key without Password;
    2.fvdi 2 support Toyota OTC V11.00.017;
    3. fvdi 2 support JLR SDD V146.00, Jaguar and land rover JLR SDD registration code is free, JLR SDD Coded Access Password is free.
    4.fvdi 2 support FLY OBD Terminator all functions.
  17. #1272
    Aug 2016
    FLy OBD terminator what is the functions?
  18. #1273
    Feb 2010
    South Africa
    Quote Originally Posted by totoo View Post
    Please can you help with contact details ,email address for the right person to contact , thanks regards
  19. #1274
    Sep 2015
    allmost any passthru device support honda,toyota,jlr,ids....etc..can you tel us wich functions are relised and working in obd terminator?where are airbags,locksmih,sinchronization?nowone want to give clear answer about this...when this terminator will be relest fully?all cars and how much will cost full version?
  20. #1275
    benzgeek's Avatar
    May 2012
    California
    Hello mates ,
    i have FVDI , chinese with Mercedes V6.1 software i wonder if i can update it ,
    thanks .
