Page 169 of 183 FirstFirst ... 69119159164165166167168169170171172173174179 ... LastLast
Results 2,521 to 2,535 of 2733
  1. #2521
    Apr 2021
    CHINA
    Quote Originally Posted by andreia67 View Post
    它是免费使用的,不需要任何费用
    SVCI 2020 V12.0 https://mega.nz/file/Z8hGjQDK#bRwvtu...4tEYt8DiRu6nQs
  2. The Following User Says Thank You to SVCI WU For This Useful Post:
    urbajs (23rd September, 2021)
  3. #2522
    Jan 2010
    DUPNICA BULGARIA
    Hi. I have vvdi bmw tool and i try to read isn from egs in to bmw e70-6hp. i nave mesage: server calculating....filed to conect update server. (2) or CMD: 1183. What is problem.
  4. #2523
    Aug 2011
    GB
    Can I use FVDI 2014 to safely reset smartkeybox 89990A and immobox 89784
    on a GRJ200 2012 Land Cruiser Toyota
    Regards
  5. #2524
    Jun 2016
  6. #2525
    Home
    Keep in mind, English is not my native language.
  7. The Following User Says Thank You to Domi For This Useful Post:
    NONO59 (6th November, 2021)
  8. #2526
    Oct 2015
    My vw software v18 stoped work with k tag. Without ktag normal work. Other vw version work with k tag. Any suggestion?
  9. #2527
    Mar 2018
    2020 is the same? Is not offline?
  10. #2528
    Mar 2018
    Quote Originally Posted by flyfvdi View Post
    FVDI 2015, 2016, 2018, 2019 and fvdi 2 all are online version.
    They always were blocked anytime by STIC company zhu engineer.
    FVDI 2014 is offline version.
  11. #2529
    Aug 2019
    Bucharest Romania
    Quote Originally Posted by negrogerardo View Post
    2014 2019 2020 are offline.
    2015 2016 2018 are online.
  12. #2530
    Sep 2013
    Friends someone have sucess with Fiat Ducato 2009 id 46 bsi NEC + 95c160 reading with fvdi 2014.
  13. #2531
    number7hd's Avatar
    Dec 2013
    I have clone 2018 which is locked (no communication with computer via USB). I have found some BOOTLOADER and upload it - now comunication is back, but I think bootloader was from 2014 ver.
    I'm looking for someone who can help me - I will pay.
    If my solution helped You - do not forget to THANKS !!!
  14. #2532
    Oct 2020
    Bulgaria
    Quote Originally Posted by Col19 View Post
    Hi friends Thanks Exxl for the answer but it doesn't really answer the question.
    If I solder a new battery to the back of the PCB in parallel (without removing the current battery) is there any way to keep it ?
    Example: the current battery gives 3.25V, i solder a second battery with a switch on the back of the PCB, when the first drains (2.8V or less) i activate the mini switch to turn on the second battery soldered to the 'rear and replace the first with another battery with switch, when the voltage of the second battery drops to 2.8V or less i activate the first which will have 3.3V and so on ...
    in this way it would be possible to keep it for a long time ?
    Thanks for your advices. I saw some mini CR2032 battery slot with switch and two long threads (+ and -) to be soldered on Alie,
    I will share the links if you confirm this method could have worked.
    Thank you.
    i am also interested of battery replacement. Are removing battery Really lock device? Someone tested?
  15. #2533
    Nov 2021
    hi
    which device from FDVI year and where should I buy it.
    Are there any suggestions or recommendations?
  16. #2534
    Dec 2017
    Hello Guys, i am glad this Thread is still active.
    I have FVDI 2018 and I can't find the Software anywhere. https://mega.nz/file/KRBzVIrD#uE0ZGj...0IF9R3Wad21f7g
    Is this the only Link i need to install it properly?
    Thanks !!
  17. #2535
    carradio2001's Avatar
    Nov 2009
    France
    Quote Originally Posted by henkgr View Post
    does anyone know what part K1-K13 and where to buy
    I recommend a good quality here --> https://www.farnell.com/
    BR,
    Carradio2001/
