Page 146 of 183 FirstFirst ... 4696136141142143144145146147148149150151156 ... LastLast
Results 2,176 to 2,190 of 2733
  1. #2176
    yellowstilo's Avatar
    Nov 2009
    STiC = FLY.....
  2. #2177
    Junior Member MeMBraNe's Avatar
    Jun 2018
    Quote Originally Posted by xyz001 View Post
    please buy fvdi 2014, fvdi 2014 is offline, fvdi 2018 always was blocked, then fvdi 2018 = brick. fvdi 2014 and fvdi 2018 has same functions , fvdi 2018 just modify the software version number .
    I've gone to zero days and no problems with activation or reactivation
    Sent from my GT-I8190 using Tapatalk
  3. #2178
    Jun 2018
    Quote Originally Posted by marassa View Post
    hello all the best i have abrites FVDI clone 2015 with ID:F11251 i have lost my soft can Sam one Upload the soft
    It's available on fly's website.
  4. #2179
    Jun 2013
    Quote Originally Posted by yellowstilo View Post
    STiC = FLY.....
    no, stic is not fly,
  5. #2180
    Jun 2018
    I've been told stic 2018 is original?
  6. #2181
    Oct 2016
    hi,
    yes the FVDI 2018 con not read the volvo you only can change the odometer !
    me was told i ll have to wait for a new firmware
  7. #2182
    Oct 2016
    Quote Originally Posted by afdiagnostics View Post
    Hello there do we have any person from these fvdi clone tools I just bought 1 but not happy it doesn’t communicate with Volvo now not sure if lost my money bought it off AliExpress
    hi,
  8. #2183
    Oct 2012
    World
    flyobd.com web site is not available
  9. #2184
    Jun 2013
    Quote Originally Posted by Smallblock454 View Post
    maybe stic company (www.flyobd.com) was dead.
  10. #2185
    Jun 2018
    Quote Originally Posted by MeMBraNe View Post
    Fvdi 2018 able to renew used pcf7945 key. Is it also able to add key to bcm2 on audi A4?
    Sent from my EVA-L09 using Tapatalk
    Just an update to all in the future, i succeeded doing this with FVDI2018. Renewed key with kd-x2, modified antenna on programmer and bobs your uncle, coded the key without even taking the pcb out of the key shell. However, the China key was unable to be programmed (failed at 98%, even with antenna right on the chip) only an original that i renewed worked.
  11. The Following User Says Thank You to MeMBraNe For This Useful Post:
    Ocin (11th May, 2019)
  12. #2186
    Oct 2018
    Romania
    Quote Originally Posted by doctore View Post
    only from ccm dump i downloads one to show youAttachment 550631Attachment 550632Attachment 550633
    est can do on obd
    I tried with FVDI 2015, special function "Key learning", wizard mode, on Passat B6. It autodetected the pin, but I couldn't program a new key. When it is in adaptation process the immo symbol dissapear, recognize the key, but after the adaptation is finished the new key isn't recognised. Did I forget something ? Shall I try standard mode ?
    Also, at first try, it delete also the original key, and after remake the entire procedure, the original key was learned again. It Could be a problem with the new key ?
  13. #2187
    Feb 2018
    España
    VW Multivan 2.5 TDI 174cv 2007 year AKL done with FVDI 2014 v21.
  14. #2188
    Jun 2013
    fly boss gary said: fvdi source code is free for everybody in the world
  15. #2189
    Jul 2013
    Slovakia
    VW Passat B6 read pin and learning key all done
    Odoslané z môjho iPhone cez Tapatalk
  16. #2190
    Aug 2011
    Just got my FVDI 2014 but can not read BCM ECU or CLOCKS on my Corsa D am trying to retrieve the security code!
    Any help would be great thanks
